CME 8.6 - CKEM
Stefan Walter
Hello everyone,
I've a problem regarding CME 8.6 + 8961 phones with CKEM.
our customer contacted us with following problem. He needs to configure the CKEM with a few extension to check the status of internal numbers.
It is an CME 8.6 with IOS - 15.1(4)M. Is there any solution to get the CKEM working ? Can everyone provide me the syntax ?
Or it is true that CKEM modules are supportet with CME 9.1 ?
Thanks /
Stefan
2 Accepted Solutions
28xx and 38xx are ISR G1.
Then I assumed wrong, and having a support contract, you can update without any problem.
7 Replies 7
Rob Huffman
Hi Stefan,
It does require CME 9.1 my friend
Here's the version history note;
9.1
KEM Support for Cisco Unified 8961, 9951, and 9971 SIP IP Phones
Increases line key and feature key appearances, speed dials, or programmable buttons on Cisco Unified SIP IP phones.
from;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmeroad.html
Cheers!
Rob
"Celebration it's around us, every nations, all around us.
Singin' forever young, singin' songs underneath that sun" - K'naan
Hello Rub,
thanks for your fast reply.
I understand that the KEM ist only supported with CME 9.1. It is possible to get the IOS 15.1(4)M.
The question is, are there any License restrictions ? Do you have an Upgrade Guide or something like that.
thank for help!
Stefan
Stefan Walter
Can you explain me, how I can check if it is an ISR G1 ? I'm New in this support Team.
It is an 2921 router but I cant find any Hardware compability in that case
Thanks for help
It is an 2921 router.
there are no license needed to upgrade ? Because the IOS is available but, the customer do not have any Contracts valid.
In this case I'm not sure to upgrade the IOS.
License Information:
Technology Package License Information for Module:'c2900'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      None          None          None
uc            uck9          Permanent     uck9
data          None          None          None
/Stefan
