CME 8.6 Inbound SIP Oddities
dbarsky88
Hi everyone,
I have a cisco 3825 running 15.1(3) with CME 8.6. I have a sip trunk registered to a voip.ms SIP account and 2 voip.ms DID's that I intend to use for inbound calling to the system. A few things to note right off the bat:
  • Voip.ms SIP accounts are registering fine
  • I can place outbound calls and everything behaves as expected (ie, translation pattern generates outbound CID etc)
  • I have used multiple online docs for CME to Voip.ms config samples and I can't seem to get inbound calls to work.
  • As far as call flow is concerned the goal is to have the call come to an inbound dial peer (dial-peer voice 10 voip) and then be translated to the number of one of my ephone DN's (see translation-rule 8)
  • When calling either of my DID's the result is a fast-busy.
Please see the relevant parts of my config for details:
voice service voip
ip address trusted list
  ipv4 0.0.0.0 0.0.0.0
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
no supplementary-service sip moved-temporarily
no supplementary-service sip refer
sip
  registrar server expires max 250 min 200
  no call service stop
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
voice register global
max-dn 100
max-pool 100
voice translation-rule 1
rule 1 /\(..........\)/ /9\1/
voice translation-rule 4
rule 1 /91+/ /1/
voice translation-rule 5
rule 1 /9011+/ /011/
voice translation-rule 7
rule 1 /41../ /12222222222/
rule 2 /43../ /12222222222/
rule 3 /44../ /12222244444/
rule 4 /42../ /12222255555/
voice translation-rule 8
rule 1 /2222225555/ /1000/
rule 2 /2222224444/ /1001/
voice translation-profile CALLER-ID
translate calling 7
voice translation-profile INCOMING
translate called 8
voice translation-profile INTERNATIONAL
translate calling 7
translate called 5
voice translation-profile OUT11DIGIT
translate calling 7
translate called 4
description [BDG] VOIP.MS 11 DIGIT OUT
translation-profile incoming INCOMING
translation-profile outgoing OUT11DIGIT
destination-pattern 91[2-9]..[2-9]......
session protocol sipv2
session target dns:chicago.voip.ms
incoming called-number .
dtmf-relay rtp-nte
codec g711ulaw
no vad
dial-peer voice 11 voip
description [BDG] VOIP.MS INTERNATIONAL OUT
translation-profile outgoing INTERNATIONAL
destination-pattern 9011T
dtmf-relay rtp-nte
codec g711ulaw
no vad
sip-ua
credentials username AAAAAAAA password 7 XXXXXXXXXXXX realm chicago.voip.ms
authentication username AAAAAAAA password 7 XXXXXXXXXXXXX
nat symmetric role active
nat symmetric check-media-src
no remote-party-id
retry invite 3
retry register 3
timers register 150
registrar 1 dns:chicago.voip.ms expires 300
sip-server dns:chicago.voip.ms
connection-reuse
I ran a debug voip dialpeer and here is the result during an inbound call. What I don't understand is why CME is attemping to match an inbound call to an outgoing dial peer. See below:
Aug 13 17:38:11.592: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersCore:
   Calling Number=7736735515, Called Number=7736735515, Peer Info Type=DIALPEER_INFO_SPEECH
   Match Rule=DP_MATCH_DEST; Called Number=7736735515
   No Outgoing Dial-peer Is Matched; Result=NO_MATCH(-1)
Aug 13 17:38:11.592: //-1/xxxxxxxxxxxx/DPM/dpMatchSafModulePlugin:
   dialstring=7736735515, saf_enabled=1, saf_dndb_lookup=1, dp_result=-1
Aug 13 17:38:11.592: //-1/xxxxxxxxxxxx/DPM/dpMatchPeersMoreArg:
   Result=NO_MATCH(-1)
Oddly enough, if I add two dial-peers like below (since it seems its looking for an outbound dial peer) the configuration works, but this is messy and a workaround.
dial-peer voice 20 voip
destination-pattern 2222225555
session target ipv4:10.1.20.2
dtmf-relay rtp-nte
no vad
dial-peer voice 21 voip
destination-pattern 2222224444
dtmf-relay rtp-nte
no vad
Does anyone have any ideas as to why this is happening?
Thanks!
18 Replies 18
d bug ccsip message is enough. Then I think dialpeer has some more options.
Can you please send the following:
1. sh run
2. debug voip ccapi inout
3.debug ccsip messages
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
aokanlawon,
When I ran debug voip ccapi inout there was no output when I placed an inbound call.
Below is what I got after running debug ccsip messages:
Aug 14 13:44:21.770: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:7736735515@173.161.54.73:1168 SIP/2.0
Via: SIP/2.0/UDP 64.120.22.242:5060;branch=z9hG4bK6a636216;rport
To: <7736735515>
Contact: <3126764646>
Call-ID: 18962cce614c95c50786f11c0db73f73@64.120.22.242
CSeq: 102 INVITE
User-Agent: VoIPMS/SERAST
Max-Forwards: 70
Remote-Party-ID: "3126764646" <3126764646>;privacy=off;screen=no
Date: Tue, 14 Aug 2012 13:44:21 GMT
Allow: INVITE, ACK, CANCEL, OPTIONS, BYE, REFER, SUBSCRIBE, NOTIFY, INFO
Supported: replaces
Content-Type: application/sdp
Content-Length: 318
v=0
o=root 19107 19107 IN IP4 64.120.22.242
s=session
c=IN IP4 64.120.22.242
t=0 0
m=audio 10480 RTP/AVP 0 18 101
a=rtpmap:0 PCMU/8000
a=rtpmap:18 G729/8000
a=fmtp:18 annexb=no;mr=0;mg=0;jmdelay=no;mrmods=
a=rtpmap:101 telephone-event/8000
a=fmtp:101 0-16
a=silenceSupp:off - - - -
a=ptime:20
a=sendrecv
Sent:
SIP/2.0 400 Bad Request - 'Invalid Host'
To: <7736735515>;tag=46F7B14-1AD9
CSeq: 102 INVITE
Allow-Events: telephone-event
Reason: Q.850;cause=100
Server: Cisco-SIPGateway/IOS-12.x
Content-Length: 0
Aug 14 13:44:21.786: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
ACK sip:7736735515@173.161.54.73:1168 SIP/2.0
CSeq: 102 ACK
Max-Forwards: 70
Content-Length: 0
Aug 14 13:44:27.490: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
REGISTER sip:chicago.voip.ms:5060 SIP/2.0
Via: SIP/2.0/UDP 10.1.20.2:5060;branch=z9hG4bK3F6F1216
From: <>139095_CME@chicago.voip.ms>;tag=46F916C-F45
To: <>139095_CME@chicago.voip.ms>
Date: Tue, 14 Aug 2012 13:44:27 GMT
Call-ID: E0CF4A50-E49F11E1-8002F453-C9A2C97C
User-Agent: Cisco-SIPGateway/IOS-12.x
Max-Forwards: 70
Timestamp: 1344951867
CSeq: 599 REGISTER
Contact: <139095_CME>
Expires:  300
Supported: path
Content-Length: 0
Aug 14 13:44:27.506: //9228/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.1.20.2:5060;branch=z9hG4bK3F6F1216;received=10.1.20.2
CSeq: 599 REGISTER
Supported: replaces
Content-Length: 0
Aug 14 13:44:27.510: //9228/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 401 Unauthorized
To: <>139095_CME@chicago.voip.ms>;tag=as1a113db9
CSeq: 599 REGISTER
Supported: replaces
WWW-Authenticate: Digest algorithm=MD5, realm="chicago.voip.ms", nonce="5fefdcb9"
Content-Length: 0
Aug 14 13:44:27.510: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
Via: SIP/2.0/UDP 10.1.20.2:5060;branch=z9hG4bK3F7011AB
Max-Forwards: 70
CSeq: 600 REGISTER
Expires: 300
Authorization: Digest username="139095_CME",realm="chicago.voip.ms",uri="sip:chicago.voip.ms:5060",response="0e9915cec4eb6afaa407e9819ac09035",nonce="5fefdcb9",algorithm=MD5
Content-Length: 0
Aug 14 13:44:27.526: //9228/000000000000/SIP/Msg/ccsipDisplayMsg:
Received:
SIP/2.0 100 Trying
Via: SIP/2.0/UDP 10.1.20.2:5060;branch=z9hG4bK3F7011AB;received=10.1.20.2
CSeq: 600 REGISTER
Supported: replaces
Content-Length: 0
Received:
SIP/2.0 200 OK
CSeq: 600 REGISTER
Supported: replaces
Expires: 300
Contact: <139095_CME>;expires=300
Content-Length: 0
Here is the output of the sh run:
! Last configuration change at 08:39:44 cdt Tue Aug 14 2012 by admin
! NVRAM config last updated at 08:39:48 cdt Tue Aug 14 2012 by admin
version 15.1
hostname CME1
boot-start-marker
boot system flash c3825-advipservicesk9-mz.151-3.T2.bin
boot-end-marker
enable secret 5 REMOVED
enable password HIDDENPASSWORD
aaa new-model
aaa session-id common
clock timezone CST -6 0
clock summer-time cdt recurring
dot11 syslog
ip source-route
ip cef
ip domain name barsky.corp
ip name-server 10.1.10.10
no ipv6 cef
voice-card 0
dspfarm
voice service voip
sip
  bind control source-interface Vlan20
  bind media source-interface Vlan20
  header-passing
voice class codec 1
max-dn 100
max-pool 100
rule 1 /91+/ /1/
rule 1 /41../ /18476753705/
rule 2 /43../ /18476753705/
rule 3 /44../ /18476753705/
rule 4 /42../ /17736735515/
rule 1 /8476753705/ /1000/
rule 2 /7736735515/ /1001/
translate calling 7
translate called 8
translate calling 7
translate called 5
translate calling 7
translate called 4
license udi pid CISCO3825 sn SERIALNUMBER
username admin password 0 HIDDENPASSWORD
redundancy
ip ssh time-out 60
ip ssh version 2
interface GigabitEthernet0/0
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no mop enabled
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
no mop enabled
interface FastEthernet2/0
description SWITCH TRUNK
switchport mode trunk
speed 100
interface FastEthernet2/1
description VOICE/DATA PORT
switchport trunk native vlan 10
switchport voice vlan 20
spanning-tree portfast
interface FastEthernet2/2
interface FastEthernet2/3
interface FastEthernet2/4
interface FastEthernet2/5
interface FastEthernet2/6
interface FastEthernet2/7
interface FastEthernet2/8
interface FastEthernet2/9
interface FastEthernet2/10
interface FastEthernet2/11
interface FastEthernet2/12
interface FastEthernet2/13
interface FastEthernet2/14
interface FastEthernet2/15
interface FastEthernet2/16
interface FastEthernet2/17
interface FastEthernet2/18
description DRAC-ESX1
interface FastEthernet2/19
interface FastEthernet2/20
interface FastEthernet2/21
interface FastEthernet2/22
interface FastEthernet2/23
interface FastEthernet2/24
interface FastEthernet2/25
interface FastEthernet2/26
interface FastEthernet2/27
interface FastEthernet2/28
interface FastEthernet2/29
interface FastEthernet2/30
interface FastEthernet2/31
interface FastEthernet2/32
interface FastEthernet2/33
interface FastEthernet2/34
interface FastEthernet2/35
interface Vlan1
description MANAGEMENT
ip address 10.1.1.2 255.255.255.0
ip helper-address 10.1.10.10
interface Vlan10
description DATA
ip address 10.1.10.2 255.255.255.0
interface Vlan20
description VOICE
ip address 10.1.20.2 255.255.255.0
interface Vlan30
description NOT USED
ip address 10.1.30.2 255.255.255.0
interface Vlan40
description GUESTS
ip address 10.1.40.2 255.255.255.0
ip forward-protocol nd
ip http server
no ip http secure-server
ip http path flash:GUI
ip route 0.0.0.0 0.0.0.0 10.1.10.1
logging esm config
tftp-server flash:Phones/dsp42.9-1-1TH1-16.sbn alias dsp42.9-1-1TH1-16.sbn
tftp-server flash:Phones/DSP69xx.0-0-0-4.zz.sgn alias DSP69xx.0-0-0-4.zz.sgn
tftp-server flash:Phones/jar11sccp.9-1-1TH1-16.sbn alias jar11sccp.9-1-1TH1-16.sbn
tftp-server flash:Phones/SCCP69xx.9-1-1-0.zz.sgn alias SCCP69xx.9-1-1-0.zz.sgn
tftp-server flash:Phones/tertp-nte
tftp-server flash:Phones/apps11.9-1-1TH1-16.sbn alias apps11.9-1-1TH1-16.sbn
tftp-server flash:Phones/apps42.9-1-1TH1-16.sbn alias apps42.9-1-1TH1-16.sbn
tftp-server flash:Phones/BOOT69xx.0-0-0-14.zz.sgn alias BOOT69xx.0-0-0-14.zz.sgn
tftp-server flash:Phones/cnu11.9-1-1TH1-16.sbn alias cnu11.9-1-1TH1-16.sbn
tftp-server flash:Phones/cnu42.9-1-1TH1-16.sbn alias cnu42.9-1-1TH1-16.sbn
tftp-server flash:Phones/CP7905080003SCCP070409A.sbin alias CP7905080003SCCP070409A.sbin
tftp-server flash:Phones/CP7905080003SCCP070409A.zup alias CP7905080003SCCP070409A.zup
tftp-server flash:Phones/CP7912080004SCCP080108A.sbin alias CP7912080004SCCP080108A.sbin
tftp-server flash:Phones/cvm11sccp.9-1-1TH1-16.sbn alias cvm11sccp.9-1-1TH1-16.sbn
tftp-server flash:Phones/cvm42sccp.9-1-1TH1-16.sbn alias cvm42sccp.9-1-1TH1-16.sbn
tftp-server flash:Phones/dsp11.9-1-1TH1-16.sbn alias dsp11.9-1-1TH1-16.sbn
tftp-server flash:Phones/jar42sccp.9-1-1TH1-16.sbn alias jar42sccp.9-1-1TH1-16.sbn
tftp-server flash:Phones/P00308010200.bin alias P00308010200.bin
tftp-server flash:Phones/P00308010200.loads alias P00308010200.loads
tftp-server flash:Phones/P00308010200.sb2 alias P00308010200.sb2
tftp-server flash:Phones/P00308010200.sbn alias P00308010200.sbn
tftp-server flash:Phones/P00405000700.bin alias P00405000700.bin
tftp-server flash:Phones/P00405000700.sbn alias P00405000700.sbn
tftp-server flash:Phones/S00105000400.sbn alias S00105000400.sbn
tftp-server flash:Phones/SCCP11.9-1-1SR1S.loads alias SCCP11.9-1-1SR1S.loads
tftp-server flash:Phones/SCCP42.9-1-1SR1S.loads alias SCCP42.9-1-1SR1S.loads
tftp-server flash:Phones/SCCP69xx.9-1-1-0.loads alias SCCP69xx.9-1-1-0.loads
tftp-server flash:Phones/term06.default.loads alias term06.default.loads
tftp-server flash:Phones/term11.default.loads alias term11.default.loads
tftp-server flash:Phones/term42.default.loads alias term42.default.loads
tftp-server flash:Phones/term62.default.loads alias term62.default.loads
control-plane
mgcp profile default
dtmf-relay rtp-nte
codec g711ulaw
no vad
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 500 voip
description EXCHANGE UM
destination-pattern 5000
session target ipv4:10.1.10.11
session transport tcp
dtmf-relay rtp-nte
codec g711ulaw
fax rate disable
fax protocol pass-through g711ulaw
no vad
dial-peer voice 600 voip
description EXCHANGE BRS AA
destination-pattern 6000
dtmf-relay rtp-nte
codec g711ulaw
fax rate disable
no vad
sip-ua
credentials username 139095_CME password 7 HIDDENPASSWORD realm chicago.voip.ms
authentication username 139095_CME password 7 HIDDENPASSWORD
no remote-party-id
retry invite 3
retry register 3
timers register 150
connection-reuse
telephony-service
no auto-reg-ephone
fxo hook-flash
max-ephones 100
max-dn 100 no-reg
ip source-address 10.1.20.2 port 2000
service phone thumbButton1 PTTH6
service dss
system message * SYSTEM MESSAGE *
cnf-file perphone
load 7914 S00105000400
load 7905 CP7905080003SCCP070409A
load 7906 SCCP11.9-1-1SR1S.loads
load 7911 SCCP11.9-1-1SR1S.loads
load 7960-7940 P00308010200.loads
load 7942 SCCP42.9-1-1SR1S.loads
load 7962 SCCP42.9-1-1SR1S.loads
load 6941 SCCP69xx.9-1-1-0.loads
time-zone 8
voicemail 5000
mwi relay
max-conferences 4 gain -6
moh music-on-hold.au
multicast moh 239.1.1.5 port 2000
web admin system name root secret 5 HIDDENPASSWORD
transfer-system full-consult dss
secondary-dialtone 9
create cnf-files version-stamp 7960 Aug 10 2012 09:23:59
ephone-dn-template  1
description BDG-SK
ephone-dn-template  2
description BDG-LS
ephone-dn-template  3
description BDG-LP
ephone-dn-template  4
description BDG-LW
ephone-template  1
softkeys hold  Newcall Resume
softkeys idle  Newcall Pickup Dnd
softkeys seized  Endcall Redial Pickup
softkeys alerting  Endcall
softkeys connected  Endcall Hold Park Trnsfer Flash
softkeys ringing  Answer Dnd
ephone-dn  10  dual-line
ring external
number 1000 no-reg
label (847)675-3705
name (847)675-3705
call-forward busy 6000
call-forward noan 6000 timeout 20
huntstop channel
hold-alert 20 shared
ephone-dn  11  dual-line
ring external
number 1001 no-reg
label (773)673-5515
name (773)673-5515
huntstop channel
ephone-dn  20
number 2000 no-reg
name Page All
paging ip 239.1.1.2 port 2000
paging group 21,22
ephone-dn  21
number 2001 no-reg
name Page BRS
paging ip 239.1.1.3 port 2000
ephone-dn  22
number 2002 no-reg
name Page Remote
paging ip 239.1.1.4 port 2000
ephone-dn  40  dual-line
number 4201 no-reg
label LS-Dmitry x4201
name Barsky, Dmitry
ephone-dn  41  dual-line
number 4101 no-reg
label BRS-Lobby x4101
name Lobby, BRS
ephone-dn  42  dual-line
number 4102 no-reg
label BRS-Office x4102
name Office, BRS
ephone-dn  43  dual-line
number 4103 no-reg
label BRS-Green x4103
name Green, BRS
ephone-dn  44  dual-line
number 4104 no-reg
label BRS-Yellow x4104
name Yellow, BRS
ephone-dn  45  dual-line
number 4105 no-reg
label BRS-Lounge x4105
name Lounge, BRS
ephone-dn  46  dual-line
number 4301 no-reg
label LP-Clare x4301
name Barsky, Clare
ephone-dn  47  dual-line
number 4401 no-reg
label LW-Valerie x4401
name Barsky, Valerie
ephone  10
device-security-mode none
description BRS-Lobby
mac-address 0014.A85F.DFE0
ephone-template 1
paging-dn 21
type 7960
button  1:41 2:10 3s11 4m43
button  5m46 6m47
ephone  11
description BRS-Office
mac-address 001C.58F9.6059
ephone-template 1
paging-dn 21
type 7906
button  1o42,10
ephone  12
description BRS-Green
mac-address 0004.4D02.1681
ephone-template 1
paging-dn 21
type 7940
button  1:43 2:10
ephone  13
description BRS-Yellow
mac-address 001D.A23E.F9E4
ephone-template 1
paging-dn 21
type 7911
button  1:44
ephone  14
description BRS-Lounge
mac-address 0019.E78E.D444
ephone-template 1
paging-dn 21
type 7940
button  1:45 2:10
ephone  20
description LS-Dmitry
mac-address ECC8.8211.40BA
ephone-template 1
paging-dn 22
type 7962
button  1:40 2:11 3s10 4m41
button  5m46 6m47
ephone  30
description LP-Clare
mac-address 5475.D02A.DD24
ephone-template 1
max-calls-per-button 2
paging-dn 22
type 6941
button  1:46 2:10 3s11 4m47
ephone  40
description LW-Valerie
mac-address 0021.5503.8B1C
ephone-template 1
paging-dn 22
type 7911
button  1o47,10
ephone  50
mac-address 88AE.1DAF.CF67
ephone-template 1
paging-dn 22
type CIPC
button  5m46 6m47
line con 0
line aux 0
line vty 0 4
exec-timeout 30 0
privilege level 15
password balrus
transport input telnet ssh
scheduler allocate 20000 1000
ntp update-calendar
ntp server 10.1.10.10
end
A call needs two legs..
In this case one leg is from SIP provider to CME, and the other leg is from CME to IP phone.
How is the ephone-dn  number  for 7736735515?
The second leg dial-peer is created by the ephone.
I think is a rule problem.
The dial-peer 21 voip create the same fuction with this dial-peer
dial-peer voice 1 voip
dtmf-relay rtp-nte
no vad
This dial-peer (1) must take the number 7736735515 trasnform with the rule (INCOMING) to get the number 1000 and then match with the ephone.
hope you get a breif config to complete all calls.
regards
Alex
