[CME] CFA to external issues afer upgrade
kamil_folga
Hi!
I'm configuring a call forwarding from internal extension to the external number:
ephone-dn 2 dual-line
number 802
name 802
call-forward all 0111222333
There is no physical phone for this DN. It`s a dummy/virtual DN that is already CFA to the outside number. This DN is in monitor button on physical phone:
ephone 1
button 1:1 2m2
User on ephone 1 press button 2 to call number 0111222333.
It`s works on IOS 15.6(3)M - CME 11.5. After upgrade to 15.7(3)M2 - CME 12.0 this not works.
Anybody help?
Best regards,
Kamil
6 Replies 6
R0g22
Can you share an output for "show dial-peer voice summary" ?
cme#show dial-peer voice summary | inc 802
20177 pots down down 802$ 0 50/0/298 NA
This configuration worked well before CME upgrade. It`s seems like I can no call forward all an ephone-dn that is not assigned to a registered phone (?)
The dial-peer is in a down state so potentially it cannot handle calls. Can you delete and re-add the DN. You would need to re-add the button command on the ephone post this.
Another extension 670, 671, 672. After delete and e-add DN:
20200 pots up up 671$ 0 50/0/299 NA
20201 pots up up 670$ 0 50/0/300 NA
20202 pots up up 672$ 0 50/0/298 NA
but when re-add button to ephone - CH1 is DOWN:
show ephone
ephone-42[41] Mac:B4A4.E328.F123
button 4: cw:1 ccw:(0)
dn 300 number 670 cfa 06XXXXXXXX CH1 DOWN monitor-ring
button 5: cw:1 ccw:(0)
dn 299 number 671 cfa 06XXXXXXXX CH1 DOWN monitor-ring
button 6: cw:1 ccw:(0)
dn 298 number 672 cfa 06XXXXXXXX CH1 DOWN monitor-ring
Extension with no CFA on the same phone are OK:
button 2: cw:1 ccw:(0 0)
dn 10 number 710 CH1 IDLE CH2 IDLE monitor-ring shared
button 3: cw:1 ccw:(0 0)
dn 12 number 712 CH1 IDLE CH2 IDLE monitor-ring shared
I remember I saw a defect sometime ago, can’t recall the code though. Let me look for it.
What platform is this ?
Thanks for your support. Platform Cisco 2951 - c2951-universalk9-mz.SPA.157-3.M2.bin
