CME on a 2901 ??
gregatatt
Hi -
I'm looking to replace my UC520. It is eol and has given me nothing but trouble.
IF, I am reading the specs right, I need the following:
CISCO2901/K9
and
SL-29-UC-K9
Will that get me Call Manager Express and Unity express?
I'll need an FXO/FXS card, but it appears those 2 parts above are the base.
Is that correct?
If not, what do I need?
THANKS!!!!
Greg
2 Accepted Solutions
Ayodeji Okanlawon
Gregory
You need this..
C2901-CME-SRST/K9
     2901 UC Bundle w/ PVDM3-16,FL-CME-SRST-25, UC License PAK
This includes all the items below:
Included: S29UK9-15204M
      Cisco 2901-2921 IOS UNIVERSAL 1
Included: FL-CME
      Cisco Communications Manager Express License 1
Included: FL-CME-SRST-25
      Communication Manager Express or SRST - 25 seat license 1
Included: ISR-CCP-EXP
      Cisco Config Pro Express on Router Flash 1
Included: MEM-2900-512MB-DEF
      512MB DRAM for Cisco 2901-2921 ISR (Default) 1
Included: MEM-CF-256MB
      256MB Compact Flash for Cisco 1900, 2900, 3900 ISR 1
  Included: PI-MSE-PRMO-INSRT
      Insert, Packout - PI-MSE 1
  Included: PVDM3-16
      16-channel high-density voice and video DSP module 1
  Included: SL-29-IPB-K9
      IP Base License for Cisco 2901-2951 1
   Included: SL-29-UC-K9
      Unified Communication License for Cisco 2901-2951
Then for CUE you need this..
ISM-SRE-300-K9
      Internal Services Module (ISM) with Services Ready Engine 1
For your FXO/FXS (depending on which you need..two ports or four ports
VIC2-4FXO
      Four-port Voice Interface Card - FXO (Universal) 1
VIC3-2FXS/DID
      Two-Port Voice Interface Card- FXS and DID 1
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
If you looked at the BOM I posted above this license is there and its explained..It is the UC license for your CCME gatewau
5 Replies 5
Ayodeji Okanlawon
Gregory
You need this..
C2901-CME-SRST/K9
Included: FL-CME
  Included: PVDM3-16
ISM-SRE-300-K9
VIC2-4FXO
VIC3-2FXS/DID
Hi Greg,
You'll need you UCK9 (Voice) licenses which sould be permanent while you purchase them from Cisco.
-Regards,
Kevin
Thanks, but what is a UCK9 license?
Hey,
UCK9 are voice licenses which are introduced in ISR-G2 ( 2900,3900).
These are technology specific license and will have to permanent inorder to run CME.
Table 3     Technology Package Licenses Supported on Modular Cisco ISR G2 Platforms
1900 Series
2900 Series
3900 Series
ipbasek9
Yes
Yes
Yes
securityk9_npe1
Yes
Yes
Yes
securityk92
Yes
Yes
Yes
datak9
Yes
Yes
Yes
uck9 (Unified Communications)
Yes
Yes
And the above reference from aokanlawon  is right too.
Here is a post for better understanding:
https://supportforums.cisco.com/thread/2114129
Kindly rate the post accordingly.
-Regards,
Kevin
