CME - ringing two phones at once
mmedwid
Level 3
Level 3
If a call comes in on an FXO and I want to ring both an analog phone (on an FXS port) and an IP phone at the same time when this occurs - how to configure this? hunt-group?
6 Replies 6
paolo bevilacqua
You need to configure the FXS port in SCCP mode - the manual explains how to do that.
mmedwid
Level 3
Level 3
I think I found the answer in hunt-group parallel..
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/admin/configuration/guide/cmecover.html#wp1145800
..aka "Call Blast"
Not sure if hunt -group paralles support s pots DP.
..and worse if you're using prior to 4.3 CM software only SIP phones are supported. :-( But perhaps if I upgrade to 4.3 and use your SCCP command on the FXS port I'd be in business??
SCCP controlled ports is from 4.0 or so (I may be wrong). Then you don't necessarily need hunt-group, a shared line can be is enough.
Justin Brenton
Level 4
Level 4
Hi mmedwid,
A shared line will accomplish this.
Justin
