CME Tapi Support for Windows 10
david.hopkins
Anyone know if there is a TAPI installer for Windows 10, the latest one I can find, fails to install at the end after testing connectivity ok and registering with the CME, error Can't add device. If you go to Phones & Modems after install the CIsco TSP is there in the advanced options but when you click add the Cisco does not get added.
Any thoughts
6 Replies 6
Brandon Buffin
I don't believe there is official support for Windows 10 yet. However, take a look at the following post for some suggestions to get it working.
https://supportforums.cisco.com/discussion/12578151/tapi-driver-not-working-anymore-worked-windows-81
Brandon
norbert alig
Hi there,
facing the same problem. CME TAPI on Windows 10.
Di you got a solution?
Hi there
Looks like Cisco TSP 11.5 and 12.0 supports Windows 10 (32&64 Bit)
https://developer.cisco.com/site/tapi/documents/supported-windows-os/
Hope this helps!
Cheers
Rath!
***Please rate helpful posts***
@Rath!
It seems that's the CUCM TSP.
I'm looking for CME.
Norbert
AFAIK, there is no support for CME TAPI/TSP driver for Win 10.
Any news about this topic?
