CME: Video calls between Cisco 9971 busy tone
Hi guys,
CME(9.5) IOS Version 15.3(2)T
Firmware: 9971.9-2-2SR1-9
When I tried to make a video call between two Cisco 9971 phone got busy tone in both way. I'm able to call between a Cisco 7942 and Cisco 9971 in both way so is confusing.
I'm able to see the busy tone message but I don't know why is received:
debug voip ccapi inout
6 21:54:35.215: //95/82BF983680F4/CCAPI/ccCallDisconnect:
Cause Value=17, Tag=0x0, Call Entry(Previous Disconnect Cause=0, Disconnect Cause=0)
debug ccsip messages
Sent:
SIP/2.0 486 Busy here
Attached Show Run and Call Trace.
Thanks in advance
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
__________________________________________________
7 Replies 7
Any idea?
Bruno Rangel
Hi Leo
Try enable the video capability parameter for all applicable IP phones associated with your CME, under telephony-service Menu.
Router(config-telephony)# service phone videoCapability 1
Router(config-register-global)
#apply-config
- Also try configure video bandwidth control for SIP to SIP video calls:
voice register global
mode cme
bandwidth video tias-modifier 512000 negotiate end-to-end
apply-config
Cheers
Bruno Rangel
"Se você quiser alguém em quem confiar, confie em si mesmo. Quem acredita sempre alcança"
Renato Russo
Cheers
Bruno Rangel
Please remember to rate helpful responses using the star bellow and identify helpful or correct answers
@Bruno, thanks for the repsonse but unfortunetly it didn't work, still busy tone is received.
Any idea?
I solved the issue. I changed the IOS to 15.1.4M6. Now is working fine.
Bruno (+5) for the help.
Great!!!!
Good Job! Thanks for sharing the solution
Cheers
Bruno Rangel
Renato Russo
Cheers
Bruno Rangel
Hi all,
I'm using CME 9.5 on  2911 with IOS Version 15.3(2)T and 9.2.2SR1.9 Firmware.
I have a Central site with the 2911 CME 9.5 Router.
  - One 9951 Video Phone
  - One 9971 Video Phone
  - One 7911 SCCP
  - One 7960 SCCP
  - One 7970 SCCP
At the Remote site, I have a 2811 Router (no CME) connected to:
  - one 9951 Video phone
  - one 9971 Video phone
  - one 7911 sccp
  - one 7960 sccp
My configuration seems to work well for all SCCP phones and they can call each other from both sites. I see no problem with SCCP based phones.
Also, SIP phone at the Central site, can call SIP phones at the Remote site with no apparent issue.
Howover, a remote SIP phones receives fast busy signal when trying to call a Central SIP phone.
Is this an expected behavior?  Has anyone seen a similar problem ?
Attached show run for the Cental site and remote Router
Thanks for input.
Emile
       Sorry here is the show run for the Central router and the Remote Router as an attachment
