CME with SIP Trunk and Cisco Unity Express
danm
I have a Cisco 3745 running 12.4(11)XJ2 / CME 4.1 / CUE with our PSTN access through a SIP Trunk. Everything is working ok except access to Cisco Unity Express, when it gets transferred to VM the caller hears fast busy tone.
Any Ideas? Thanks in advance.
Dan
6 Replies 6
paolo bevilacqua
Are the calls coming in with G.711? Nothing else would work with CME.
Does it fails only when transferred, or also when calling main VM number directly ? If the first, you may need to configure:
voice service voip
allow-connections sip to sip
no supplementary-service sip moved-temporarily
To confirm collect output of "debug ccsip message" with "term mon" to know a little more.
Hi Damm,
Did you solve your problem, because I'm having the same problem. Could you help me please ?
Vinicius
Please check the dial-peer configs. Sample configs below.
dial-peer voice 200 voip
description CUE-Voicemail
destination-pattern 8000
b2bua
session protocol sipv2
session target ipv4:1.1.1.1
dtmf-relay sip-notify
codec g711ulaw
no vad
Arun Thomas,
I verified the dial-peer and it doesn't have two commands "dtfm-relay sip-notify" and "no vad". After I put both commands solved my problem.
Thank you very much.
Vinicius
Happy to see that your issue is resolved. but i dont think that its the dtmf command but may be the "no vad"
Please rate post if it does!
Can you post a sample config for your setup?  It would really help me right now.  You can cure the output
