Compatibility of Cisco Unified Communications Manager
jaighobahi
Hello there,
I would like to know if the CUCM is compatible with Microsoft server 2008 and Microsoft Exchange server 2010.
Thanks.
CUCM doesn't care about Exchange, only Active Directory. The SRND has a chapter on LDAP Directory Integration which shows that the 2008 functional level is supported.
Hi Jonathon,
Is it for active directory integration?
Thanks and Regards,
Ashfaque
Yes, it is for Active Directory integration.
Thanks a lot for the information.
