Conference call
Imran Irshad
Good Day Community,
I have installed CUCM 10 and running 8845 Phones. i can have local (dial Ext.) conference call between three user but Only Audio.
is there any way to do Video Conference call between Three 8845 Phones ? '
Thank you
I.A
Chris Deren
Not without video conferencing solution.  Cisco had PVDM based ad-hoc video conferencing option, but that is no longer recommended/available on new PVMDs. As pointed out CMS is the current Cisco video solution.
Jitender Bhandari
Deepak Kumar
I suggest to check option as MTP is unchecked, Bandwidth allocation is correct, enterprise settings and enterprise phone settings are enabled for video calling etc.
for the bandwidth allocation guide as:
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/8_6_1/ccmsys/accm-861-cm/a08video.pdf
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Chris Deren
