06-08-2015 06:59 AM - edited 03-17-2019 03:15 AM
Hi all, has anyone came across the wireless mics unpairing themselves? I can succesfully pair them but once in a while (almost once a week) they randomy unpair themselves, the only thing I can imagine to be happening here is that they store them in an office where they get out of reach from the main station and they place it in the conference room right before meetings. Would this have something to do? Has anyone experienced something similiar? Any help would be highly appreciated, thanks.
Solved! Go to Solution.
06-08-2015 11:14 PM
Hi Alfredo,
If the microphones work well for 7 days continuously then the basic performance paremeters are being met. To rule out any issue with the microphones being kept away outside the range of 8831, try keeping a single set of microphones close to the 8831 for 10 or more days and check if the issue is experienced. This will at least isolate where the issue lies.
Manish
06-08-2015 11:14 PM
Hi Alfredo,
Manish
09-02-2015 02:12 PM
Keeping microphones inside the range prevents them from unpairing, thanks.
