configure FXO for faxing.
nmanhertz
I need help configuring my voice gateway 2851 FXO to forward fax to my ax server number, using CUCM 8.5.
- I have an analog line in my Canada office (FXO) and need all fax send to US fax server. -
Nigel Manhertz
Chris Deren
Configure the FXO port with plar that points to an extension that redirects the call to CUCM via a dial-peer (assuming GW is integrated to CUCM via SIP/H323), then in CUCM make sure you have a matching route pattern that redirects this call to the fax server (assuming it is already integrated).
HTH,
Chris
Chris thanks for your response.
description:
The Fax server is not integrated into CUCM and the fax number is external to CUCM.
What I am trying to accomplish, is to have the FXO port form my remote office send to my corp fax server
voice-port 0/3/1
description << to fax >>
connecton plar opx ??? (does this ext have to be configured in CUCM)
dail-peer voice 10 pots
destination-pattern xxxxxxxxxx
port 0/3/1
the gateway I am using is configured in CUCM for my voice circuit (T1).
Thanks for any help,
Nigel M
ashok_boin
Level 5
Level 5
Hi Nigel,
No need to have this extension configured but the route to that number should be available.
With best regards...
Ashok
