Copying SIp headers in CUBE
Gordon Ross
Level 9
Level 9
I'm trying to copy a SIP header and pass its value into a new SIP header. In CUBE I have:
voice class sip-profiles 2
 request INVITE sip-header From copy "<sip:(.*)>" u01
 request INVITE sip-header P-Asserted-Identity add "P-Asserted-Identity: <sip:\u01>"
But when the look at the debugs, the "\u01" isn't being replaced with the earlier value and the header looks like:
What am I doing wrong?
Gordon
Please rate all helpful posts.
9 Replies 9
Slavik Bialik
Level 7
Level 7
First of all, I see that you're trying to accomplish what you've asked about in your other post. So over there I gave you a solution based on a LUA script on the CUCM itself.
But here, why aren't you using the "modify" instead of "add"?
Because the PAI header already exists in the SIP, so I don't think it is allowing you the add another one, therefore you see the PAI header not changed. So maybe try to delete it first after you copying it's value.
You can try something like:
 request INVITE sip-header P-Asserted-Identity remove
I didn't tested the above, but I think it may work.
Because, for some unknown reason, CUBE is removing the P-Asserted-Identity header. I see it in the inbound call leg, but on the INVITE to the SP, it's removed. Hence why I'm doing it as an add. But as I said, the add is working, it's just not replacing the u01 variable.
I understand. Can you please post your CUBE configurations?
Verify that your CUBE configurations has "header-passing" under:
voice service voip
  sip
Also, found another interesting article about allowing specific headers with CUBE. Take a look:
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/voice/cube_sip/configuration/xe-3s/cube-sip-xe-3s-book/voi-conf-pass-thro.html
Search for: sip-hdr-passthrulist (cli command).
cube-dev-1(config-class)#passthru-hdr  P-Asserted-Identity
 Cannot add P-Asserted-Identity, It is mandatory/Invalid
You're right. But it makes me wondering, what's the point of sending the PAI to the ITSP?
I checked on my CUBEs and the behaviour is the same, means that's it meant to be.
The ITSP doesn't need your PAI information, so why are you trying to send it anyway?
My Telco is saying they need that header in there with just the DN, no name.
Gordon
Have you solve this issue?
pabarnech
maybe you already solved but like I didn't see the answer, so I going to share what I found.
I don't know why when you "add", the copied variable doesnt work so I made that:
First I add P-Asserted-Identiy with any data (only to copy then) and then modify with the variable, like this:
request INVITE sip-header P-Asserted-Identity add "P-Asserted-Identity: 1234"
request INVITE sip-header P-Asserted-Identity modify "P-Asserted-Identity: 1234" "P-Asserted-Identity: <sip:\u01>"
You can use this tool to test it
https://cway.cisco.com/tools/SipProfileTest/
Pablo
