COR Blocking in CME
ryan_oconnell
Level 3
Level 3
Hello all
I'm messing around with COR for a customer and I'm having the following issue. I want to use COR to block 1900 calls but I'm noticing that it's behaving not the way I thought it should. I have the following setup and here is what is happening.
When dialing 91900XXXXXXX from ephone-dn 1 I'm noticing I'm getting my first match on Dial-peer 10 and the call is regected because this peer member is not in ephone-dn 1 corlist "BUT" i'm also getting a match on Dial-peer 8 which is less exact and the call is proceeding. Therefore if there is an overlap you COR doesn't work properly.
Yes I know I can use "after hours block 1 1900 7-24" under telephony services but this will block it for everyone. I want it to be flexible so that I can use COR to allow users to call 1900 if they needed to.
Thoughts?
dial-peer cor custom
name internal
name local
name domestic
name international
name 900
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-domestic
member domestic
dial-peer cor list call-international
member international
dial-peer cor list call-900
member 900
dial-peer cor list user-internal
member internal
dial-peer cor list user-local
member internal
member local
dial-peer cor list user-ld
member internal
member local
member domestic
dial-peer voice 2 pots
description **Emergency Services 911**
destination-pattern 9911
port 0/1/0:23
forward-digits 3
dial-peer voice 3 pots
corlist outgoing call-local
description **For local 7 Digit calls**
destination-pattern 9[2-9]......
port 0/1/0:23
forward-digits 7
dial-peer voice 9 pots
corlist outgoing call-international
description **International LD calls**
destination-pattern 9011T
port 0/1/0:23
prefix 011
dial-peer voice 10 pots
corlist outgoing call-900
description **Toll Charge Calls**
destination-pattern 91900.......
port 0/1/0:23
forward-digits 11
dial-peer voice 11 pots
destination-pattern 91976.......
port 0/1/0:23
forward-digits 11
dial-peer voice 8 pots
corlist outgoing call-domestic
description **Domestic LD calls**
destination-pattern 91[2-9]………
port 0/1/0:23
forward-digits 11
gatekeeper
shutdown
telephony-service
no auto-reg-ephone
load 7960-7940 P00308000400
load 7941 SCCP41.8-2-2SR1S
load 7961 SCCP41.8-2-2SR1S
load 7971 SCCP70.8-2-2SR1S
load 7970 SCCP70.8-2-2SR1S
load 7906 SCCP11.8-2-2SR1S
load 7911 SCCP11.8-2-2SR1S
max-ephones 36
max-dn 108
ip source-address 10.X.X.X port 2000
system message
time-zone 6
voicemail 2499
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh music-on-hold.au
web admin system name cmeadmin secret
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
secondary-dialtone 9
create cnf-files version-stamp Jan 01 2002 00:00:00
ephone-dn 1 dual-line
number 2400 secondary 7807922400
label 2400
description Remote Site 1
name Remote Site 1
call-forward busy 2499
call-forward noan 2499 timeout 15
corlist incoming user-ld
corlist outgoing call-internal
ephone-dn 2 dual-line
number 2401 secondary 7807922401
label 2401
description Remote Site 2
name Remote Site 2
corlist incoming user-local
ephone 1
mac-address 001D.4561.5B98
username "user1" password 2400
type 7941
button 1:1
ephone 2
mac-address 001D.4543.A8FD
username "user2" password 2401
type 7941
button 1:2
6 Replies 6
vmilanov
Hi Ryan,
First CME does not match peer on the 'most specific' basis, but rather it searches the list of configured dial-peers in the order they appeared in the configuration. So, when the dial-peer was rejected, the CME hunts for the next match.
Second thing, a cor list applied as 'incoming' to a phone-dn restricts where to this ephone-dn can dial-out. It has the same function as the Line CSS has in CCM. And a cor-list applied as 'outgoing' restricts which members can dial-in, and it behaves like the partitions in a CCM environment.
In your configuration the incoming cor-list of ephone-dn 1 has all the members but the '900' member, so this dn can dial out trough all the dial-peer except the dial-peer 10.
Respectively, ephone-dn can be reached by all the dial-peers that are members of the 'internal': in your case by all the dial-peers, because the pots ones do net have cor-list at all, so they have unrestricted access, and the ephone-dn 2 has a 'internal' membership via it's outgoing cor-list.
HTH.
Vasil
Ok,
Thanks for clarifing point one, about how dial-peer are matched in order vs most exact.
And your points on the Direction of COR and how it's applied I do understand. Or at least I think I do.
But my question is not answered.
At the end of the day, if I wanted to have a user that can dial 1900 as well as everything else but still restrict 1900 from the rest of the users how do I accomplish this?
In my example I'm trying to allow Ehpone 1 to dial "Domestic" but not 1900 numbers.
Thanks Ryan
Ryan
Configure "huntstop" on the DP that are matching block.
This is the way CCA configures my UC500 to block 900 calls. Does this help?
voice translation-rule 2222
rule 1 /^91900......./ //
rule 2 /^91976......./ //
voice translation-profile CallBlocking
translate called 2222
ephone-dn 1
corlist incoming user-domestic
translation-profile incoming CallBlocking
Hi Ryan,
I saw Paolo's reply and I find it very useful. I'll rate him.
So having in mind what he advised, and to have an easy to read and clean configuration, I would do the following:
-- copy all dial-peers config to a text file
-- delete all dial-peers from the config
-- re-order the dial-peers in the text file from the most restrictive to less restrictive ones, and then by most specific to less specific destination patterns.
-- add the 'hunstop' command to each one, except those used for local and emergency dialing.
-- re-assign the dial-peer numbers from top to bottom.
-- paste back the new dial-peers config to IOS.
With your config it would look this way:
dial-peer voice 1 pots
huntstop
port 0/1/0:23
forward-digits 11
huntstop
port 0/1/0:23
forward-digits 11
huntstop
port 0/1/0:23
prefix 011
dial-peer voice 4 pots
huntstop
port 0/1/0:23
forward-digits 11
dial-peer voice 5 pots
port 0/1/0:23
forward-digits 7
dial-peer voice 6 pots
port 0/1/0:23
forward-digits 3
Vasil
I did give his suggestion a try on Friday, just how you outlined and it did not work.
