ATTENTION: We are currently working an issue with posting. Thank you for your patience while we work on a resolution.
Corporate Directory Name Display order
andersson1970
HI,
I have installed CUCM 9.1. In IP Phone corporate directory when user is search output it output shows "Last name First Name".
Can it be changed to "First name Last Name"?
Andy
2 Accepted Solutions
Chris Deren
No, the directory XML pages are not changeable on appliance based CUCM.  It used to be possible back in the Windows days, but not anymore.
HTH,
Chris
There is no way to modify the default corporate directory application on the CUCM appliance. If you want to change this, you will need to develop a directory application on a separate web server.
Check this post:https://supportforums.cisco.com/thread/2017068
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
__________________________________________________
Chris Deren
HTH,
Chris
It is not necessary to develop what already exists.
You can take a look to 2Ring PHONE SERVICES at http://www.2ring.com/NewJuice
Martin
