Bookmark
Subscribe
7874
Create LOCAL Users via BAT Import with LDAP Sync Enabled CUCM 9.1(2)
cary.chapman
We have a CUCM 9.1.2 cluster with LDAP enabled. Currently the customer is consolidating their numerous domains into a better structure so we do not want to import LDAP enabled users at this time, we want to import users as local users and we'll migrate them to LDAP users later. However, when we attempt to import users in BAT we get the following error and it fails:
Warning :
LDAP Sync status is enabled.Some fields cannot be updated.
username_is_here Password should be specified either in CSV file or default credential for Password should be set
We can add local users manually without any issues. Is there a field or something that can be enabled so CUCM will BAT import local users? Thanks.
Gregory Brunn
Cary
Based on a quick read of your error message I am seeing that you are either no supplying the password or that you have not set the default credential policy for the users.
I would try to set you default credential policy and try again.
If you think you have everything set up correctly send me the exact version of 9.1.2 your running and a sample bat file.  Please sanitize it with fake info.
10 Replies 10
Gregory Brunn
Cary
I tried it as well and it does not work. In the end I added the users using the default password in the cred policy. I also tried to update the user password via BAT 'update users' but no go. There was no error but the password did not get updated.
The cucm is ldap synced and authenticated. I temporarily disabled the ldap authentication and it worked. So CUCM 10 although you can have both local and ldap synced users it does not update passwords of local users when you have ldap authentication turned on. This is a left over I guess from the pre 9.X version of CUCM
Clearly a bug that needs to be addressed
Hope this helps save somebody else's time
Christos
Christos,
Didn't you lose your user information in CUCM when you disabled the LDAP authentication? I get a warning that it will remove all the data if I do that....
Gregory - Default Credential Policy is set, I have password & pin defined in my CSV file. It's a very simple user import file format:
FIRSTNAME,LASTNAME,USERID,PASSWORD,DEPARTMENT,PIN,TELEPHONENUMBER
UserFirst,UserLast,Uname,Password1,ABC,12345,99999
I don't think 9.x will allow BAT imports of users with LDAP enabled..... but still hopeful.
That's strange because no matter how many times I tried it never managed to update the password. There was no error reported on the BAT file but only this
Warning :
******** NO ERROR FOUND *******
Result Summary :
UPDATE for 81 USERS passed.
UPDATE for 0 USERS failed.
Of course none of the 81 users got the password updated. I checked it by trying to login to the ccmuser pages where it was still the password from the default credential policy.
The warning gave me the hint to just disable the ldap authentication for a few minutes in order to start my bat update. I used the same file as always and that time it worked. I then re-enabled the ldap authentication and everything went ok. Of course if you disable the ldap authentication, synced users will not be able to authenticate but for me it was for a few seconds and I did it during out-of-business hours.
In 9.X there is a warning but in 10.X there is no such warning for some reason :)
Christos
You wont loose anything related to LDAP affects only local users.  Set the default password for local users before importing, it will work great.
Thank you @christos that worked!!
Gregory...
Okay, even though there was a Default Cred Policy set I wasn't aware the password had been deleted, I set a password and now am able to import non-LDAP users into CUCM 9.1(2). Thank you for the assist, 5 stars and appreciated!
-C-
Happy I could help!
I had the same issue as
Thanks Gregory! You saved me from having to enter a lot of end users manually.
Gotta love Cisco, "Password should be specified either in CSV file or default credential for Password should be set" - no, even if you set the password in the CSV you still need to set a password in the Default Credential Policy. Argh!
