Bookmark
Subscribe
1012
Create Transfer Button (Button Template)
alfredobosca
I want to transfer with button 2. Firstly I have configured a Button template like Image-1. After go to phone and isn't possible to configure the dial number to transfer (Image -2). I need to configure this option to one assistant.
Samuel T Mathai
yes. You can configure it I think.
Jaime Valencia
Because there has never been a way to do a simple 1 button transfer in which you configure transfer + destination, there's no way to do what you're asking, best you could do, is to configure the transfer button/softkey + a speed dial with the DN.
java
if this helps, please rate
Of course, finally I have configured both "button/softkey + SDN" and works fine.
Thanks for all!!
Finally I have configured the "Speed Dial BLF" to assistant can bring the calling to CEO. But isn't working. When assistant push the button with Speed Dial BLF configured isn't bring the calling, otherwise begin another call.
