05-14-2009 07:33 AM - edited 03-15-2019 06:01 PM
Hi, i had a problem with a gateway h323 with some MGCP parameters and SRST with MGCP fallfack. The IOS was c2800nm-advipservicesk9-mz.124-22.T.bin
The problem was that suddenly it can't receive and make calls trough the E1 and the analog lines. I made a debug and when the call come in appears the error cause 38 (Network issue) and when i want to make a call appears the error cause 47 (dsp problem)
The E1 provider saw the layer 1 down from its node but from the router "sh osdn status" i saw the layer 1 up and the layer 2 in multiframe-stablished.
Well, i resolved the problem reconfiguring the voice parameters from the gateway. But now i cannot make a csim start and appears this message:
csim: called number = 06256837, loop count = 1 ping count = 0
csim err:csim_do_test invalid major major(16) minor(0)
csim: loop = 1, failed = 0
csim: call attempted = 1, setup failed = 0, tone failed = 0
Do any of you have this problem before???
Thanks for your help.
Jose
05-20-2009 12:33 PM
If you are using SSH, then csim start doesn't work with SSH.
05-20-2009 12:40 PM
[edited due to incorrect information]
08-26-2010 05:00 AM
Oddly enough, I concur with amritpatek.
When I use the command "csim start
When I run the same command in a SSH session (puTTY as an example), I receive the same message as the OP, and the call is never attempted. No debug info is returned with every debug option I've tried. I've tried this on c2800nm-advipservicesk9-mz.124-22.T1.bin and c3825-advipservicesk9-mz.124-22.T1.bin.
Kind of wacky, no? Buy hey, at the end of the day it's an undocumented command
08-26-2010 05:29 AM
You are right, csim does not work with SSH. Note it disconnects the call right away.
That does not happen with telnet.
vg-bws-rome-1#who
Line User Host(s) Idle Location
*194 vty 0 pab idle 00:00:00 10.0.97.3
vg-bws-rome-1#sh ssh
Connection Version Mode Encryption Hmac State Username
0 2.0 IN aes256-cbc hmac-sha1 Session started pab
0 2.0 OUT aes256-cbc hmac-sha1 Session started pab
%No SSHv1 server connections running.
vg-bws-rome-1#debug isdn q931
debug isdn q931 is ON.
vg-bws-rome-1#term mon
vg-bws-rome-1#csim start 123
csim: called number = 123, loop count = 1 ping count = 0
vg-bws-rome-1#
Aug 26 14:27:26.388 CEST: ISDN BR0/0/1 Q931: Sending SETUP callref = 0x002A callID = 0x8030 switch = basic-net3 interface = User
Aug 26 14:27:26.388 CEST: ISDN BR0/0/1 Q931: TX -> SETUP pd = 8 callref = 0x2A
Bearer Capability i = 0x8090A3
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0x8A
Exclusive, B2
Called Party Number i = 0x80, '123'
Plan:Unknown, Type:Unknown
Sending Complete
Aug 26 14:27:26.408 CEST: ISDN BR0/0/1 Q931: TX -> DISCONNECT pd = 8 callref = 0x2A
Cause i = 0x80AF - Resource unavailable, unspecified
Aug 26 14:27:26.420 CEST: ISDN BR0/0/1 Q931: RX <- CALL_PROC pd = 8 callref = 0xAA
Channel ID i = 0x8A
Exclusive, B2
Aug 26 14:27:26.424 CEST: ISDN BR0/0/1 **ERROR**: Ux_BadMsg: Invalid Message for call state 11, call id 0x8030, call ref 0x2A, event 0x2
Aug 26 14:27:26.428 CEST: ISDN BR0/0/1 Q931: TX -> STATUS pd = 8 callref = 0x2A
Cause i = 0x80E202 - Message not compatible with call state or not implemented
Call State i = 0x0B
Aug 26 14:27:26.436 CEST: ISDN BR0/0/1 Q931: RX <- RELEASE pd = 8 callref = 0xAA
Cause i = 0x82AF - Resource unavailable, unspecified
Aug 26 14:27:26.444 CEST: ISDN BR0/0/1 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x2A
05-20-2009 02:40 PM
That's right before the problem i could use the csim. Did you manage any case similar to these?
06-29-2016 01:17 AM
NOTE that csim start on SSH works if you give the command in the same line of the login command (at the end of the command).
05-01-2018 01:48 PM
Confirmed it's working from ssh in both IOS or Linux.
#ssh -l admin 1.1.1.1 "csim start 915553107800"
