IP Telephony and Phones
Labels
Hello, We are currently using a Be6000 system and when we schedule a call forwarding on our phones (model 7945) to external numbers, it works perfectly when the original call comes from an internal position, but when it is an external call then this ...
Translator by Community Manager
  • 5539 Views
  • 14 replies
Hi all, i have some 6945 and 6941 IP Phones which getting no Ringtones from TFTP. You can only choose the default ringtones Chirp1 and Chirp2. Firmware is 9-4-1-3SR2 . CUCM Version: 11.5 The Phone is getting the Ringlist  from CUCM (Wireshark trace)...
I have a CME Router 2921 connected to SIP Router "Peer to Peer", which is giving me VOIP Service. i can make inbound calls normal and i can hear ringback tone when tested incoming calls from my Mobile or any landline Phone.   Issue is when i try to m...
Hi, I can't delete one device pool on CUCM.             This is the message that I received:  "Delete failed. The pkid column in the devicepool table in the database is being  referenced from another table. Please check the dependency records, remove...
Dear AllIt's really hard to understand the CUCM trace log, is there any document can help to understand it ?I know there is a sofeware VLT, it can translate the SDI trace file to easy understand form,but I think this is not good engough , and this so...
Resolved! Dialpeer Question
I'm quite sure this has been answered previously but I've been unable to find. I have a customer who has a CME box with FXS ports and a PRI interface.  The customer wishes to put an analog phone in a public location that makes only outside calls with...
johnk by Level 1
  • 462 Views
  • 10 replies
CUCM 11.5 I watched a Cisco Live presentation regarding ILS and global dial plan replication and I did not hear one mention of the actual directory number being advertised with ILS.  The only thing I heard mentioned was being able to advertise these ...
voip7372 by Level 4
  • 2635 Views
  • 7 replies
Hi Everyone , just started learning CUCM, managed to install CUCM 11.5, Unity and CUP in the lab. The systems are talking to each other, there is no AD integration, have created local users in CUCM. The Unity has AXL integration configured to pull us...
ShankarP by Level 1
  • 480 Views
  • 5 replies
Resolved! PRI NI2 Protocol
We have two PRIs for local inbound/outbound calls and a T1 for TFNs and long distance outbound.  We want to switch over the T1 to a PRI as well.  My phone provider is asking if we're going to be using NI2 protocol.  I'm not sure if we will be.  I wou...
I see several post regarding Zebra TC51 with Jabber installed..   We loaded and configured Jabber Ver 11.9 then 12.x on a TC51  Jabber phone control appears to function as expected however the Directory is not connected..  Tried UDS, BDI Service Prof...
