CSS changed after setting CFA in a phone
oracat777
Hi all,
I found that then I configure a Call Forward All by pressing button in a phone, the CFA CSS of the phone in the CUCM will changed automatically.
Is it should be like that? How can I make it does not change?
thanks in advance.
Chris Deren
Yes, this is because the CM service parameter "CFA CSS Activation Policy" is set to use "With             activating device/line CSS", you can change it and define explicit CSSes.
HTH, please rate all useful posts!
Chris
Chris Deren
Chris
hi Chris,
thanks very much.I will look careful next time.
