11-10-2018 04:41 AM - edited 03-17-2019 01:42 PM
Hi All
I am installing CUBE
However, CUBE is not registered with sip-trunk.telekom.de.
Please check the configuration and debug messages.
sip
bind control source-interface GigabitEthernet0/0/0
bind media source-interface GigabitEthernet0/0/0
rel1xx disable
session refresh
asserted-id pai
outbound-proxy dns:reg.sip-trunk.telekom.de
conn-reuse
no update-callerid
privacy-policy passthru
sip-profiles 3000
voice class sip-profiles 3000
rule 1 request REGISTER sip-header Contact modify "<.*:.*@(.*)>" "<sip:\1;bnc>"
rule 2 request REGISTER sip-header Require add "Require: gin"
sip-ua
credentials number +********* username ********* password 7 ********* realm sip-trunk.telekom.de
authentication username ********* password 7 ********* realm sip-trunk.telekom.de
no remote-party-id
timers dns registrar-cache ttl
registrar dns:sip-trunk.telekom.de expires 240 tcp auth-realm sip-trunk.telekom.de
sip-server dns:sip-trunk.telekom.de
connection-reuse
host-registrar
debug message
Nov 10 12:34:59.214: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIAddContextToTable: Added context(0x7F35BDBB9F50) with key=[61] to table
Nov 10 12:34:59.214: //-1/000000000000/SIP/Info/info/4096/ccsip_ipip_media_service_init:
Nov 10 12:34:59.214: //-1/000000000000/SIP/Info/info/4096/ccsip_tdmip_media_service_init:
Nov 10 12:34:59.214: //-1/000000000000/SIP/Info/verbose/36864/ccsip_ipip_media_forking_init: MF: Queue is initialised..
Nov 10 12:34:59.214: //-1/000000000000/SIP/Info/verbose/4097/ccsip_platform_init_ccb: Initialising rtp session queue
Nov 10 12:34:59.214: //-1/xxxxxxxxxxxx/SIP/Info/info/64/sipSPISetSipProfilesTag: voice class SIP Profiles tag is set : 3000
Nov 10 12:34:59.214: //-1/000000000000/SIP/Info/notify/262144/ccsipRegisterSetTargetInfo: p2p mode with Registrar Server = dns:sip-trunk.telekom.de
Nov 10 12:34:59.214: //-1/000000000000/SIP/Info/verbose/262144/ccsipRegisterSetTargetInfo: Parsing The Registrar Address
Nov 10 12:34:59.214: //-1/xxxxxxxxxxxx/SIP/Info/verbose/5120/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: target_host : sip-trunk.telekom.de target_port : 5060
Nov 10 12:34:59.214: //-1/xxxxxxxxxxxx/SIP/Info/verbose/5120/sipSPIGetOutboundHostAndDestHostPrivate: CCSIP: outbound_host : reg.sip-trunk.telekom.de outbound_port : 5060
Nov 10 12:34:59.214: //-1/000000000000/SIP/Info/critical/8192/sipSPIOutboundProxyReuse: Do not reuse Outbound Proxy IP adress and Port
Nov 10 12:34:59.214: //-1/000000000000/SIP/State/sipSPIChangeState: 0x7F35BDBB9F50 : State change from (STATE_NONE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_NONE)
Nov 10 12:34:59.214: //-1/000000000000/SIP/Info/verbose/6144/ccsip_spi_registrar_add_expires_header: Inside ccsip_spi_registrar_add_expires_header for Expires
Nov 10 12:34:59.215: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_OUTBOUND_REGISTER
Nov 10 12:34:59.215: //-1/xxxxxxxxxxxx/SIP/Info/info/262144/sipSPIIncrementOverloadCount: Local 1 Global 1
Nov 10 12:34:59.215: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 3 for event 40
Nov 10 12:34:59.215: //-1/000000000000/SIP/Info/verbose/262144/act_idle_outgoing_register: In act_idle_outgoing_register
Nov 10 12:34:59.215: //56/000000000000/SIP/Info/info/262144/act_idle_outgoing_register: Send REGISTER to reg.sip-trunk.telekom.de:5060
Nov 10 12:34:59.215: //56/000000000000/SIP/Info/verbose/4096/sipSPIUaddCcbToUACTable: ****Adding to UAC table.0x7F35BDBB9F50 FFFFFFFF8FFB8890-FFFFFFFFE41611E8-FFFFFFFF8007DFFB-31CC279D
Nov 10 12:34:59.215: //56/000000000000/SIP/Info/verbose/4096/sipSPIUaddCcbToTable: Added to table. ccb=0x7F35BDBB9F50 key=FFFFFFFF8FFB8890-FFFFFFFFE41611E8-FFFFFFFF8007DFFB-31CC279D balance 1
Nov 10 12:34:59.215: //-1/xxxxxxxxxxxx/SIP/Event/sipSPIEventInfo: Queued event from SIP SPI : SIPSPI_EV_DNS_RESOLVE
Nov 10 12:34:59.215: //56/000000000000/SIP/State/sipSPIChangeState: 0x7F35BDBB9F50 : State change from (STATE_IDLE, SUBSTATE_NONE) to (STATE_IDLE, SUBSTATE_SENT_DNS)
Nov 10 12:34:59.215: //56/000000000000/SIP/State/sipSPIChangeState: 0x7F35BDBB9F50 : State change from (STATE_IDLE, SUBSTATE_SENT_DNS) to (SIP_STATE_OUTGOING_REGISTER, SUBSTATE_SENT_DNS)
Nov 10 12:34:59.215: //-1/xxxxxxxxxxxx/SIP/Info/notify/8192/sip_dns_type_srv_query: TYPE SRV query for _sip._tcp.reg.sip-trunk.telekom.de and type:1
Nov 10 12:34:59.218: //-1/xxxxxxxxxxxx/SIP/Info/info/8192/sip_dns_type_a_aaaa_query: DNS query for reg.sip-trunk.telekom.de and type:1
Nov 10 12:34:59.220: //-1/xxxxxxxxxxxx/SIP/Error/sip_dns_type_a_query:
TYPE A query failed for reg.sip-trunk.telekom.de
Nov 10 12:34:59.220: //-1/xxxxxxxxxxxx/SIP/Error/_send_dns_fail:
DNS Query for reg.sip-trunk.telekom.de failed
Nov 10 12:34:59.220: //-1/xxxxxxxxxxxx/SIP/Info/info/4096/ccsip_process_sipspi_queue_event: ccsip_spi_get_msg_type returned: 2 for event 43
Nov 10 12:34:59.221: //56/000000000000/SIP/Error/act_register_dns_resolved:
DNS Query failed for query_type:1
Nov 10 12:34:59.221: //-1/xxxxxxxxxxxx/SIP/Info/notify/262144/ccsip_api_register_target_dns_resolved: ttl = -1
Nov 10 12:34:59.221: //-1/xxxxxxxxxxxx/SIP/Info/info/262144/sipSPIDecrementOverloadCount: Count:Local 0 Global 0
Nov 10 12:34:59.221: //56/000000000000/SIP/Error/ccsip_api_register_result_ind:
Message Code Class 4xx Method Code 100 received for REGISTER
Nov 10 12:34:59.221: //-1/xxxxxxxxxxxx/SIP/Info/notify/262144/ccsip_register_reset_dns_cache: CCSIP_REGISTER:: registrar 0 DNS resolved addr reset
Nov 10 12:34:59.221: //56/000000000000/SIP/Info/notify/262144/sipSPIRegPthruProcessResponse: Processing response w/ resp code == 503
Nov 10 12:34:59.221: //-1/xxxxxxxxxxxx/SIP/Info/verbose/262144/sipSPIGetRPCBFromRCB: Retreiving RCB [0x7F35BE1202F8] from RPCB [0x0]
Nov 10 12:34:59.221: //56/000000000000/SIP/Info/critical/262144/sipSPIRegPthruProcessResponse: Error NO RPCB
Nov 10 12:34:59.221: //-1/xxxxxxxxxxxx/SIP/Info/info/2048/ccsipRegisterStartRCBTimer: Starting timer for pattern +49697912790 for 120 seconds
Nov 10 12:34:59.221: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIDeleteContextFromTable: Context for key=[61] removed.
Nov 10 12:34:59.221: //56/000000000000/SIP/Info/verbose/4096/sipSPIUdeleteCcbFromTable: Deleting from table. ccb=0x7F35BDBB9F50 key=FFFFFFFF8FFB8890-FFFFFFFFE41611E8-FFFFFFFF8007DFFB-31CC279D
Nov 10 12:34:59.221: //56/000000000000/SIP/Info/verbose/4096/sipSPIFlushEventBufferQueue: There are 0 events on the internal queue that are going to be free'd
Nov 10 12:34:59.221: //56/000000000000/SIP/Error/sipSPIFlushDeferredQueue:
Invalid deferredQueue
Nov 10 12:34:59.221: //56/000000000000/SIP/Info/verbose/1/sipSPI_ipip_free_codec_profile: Codec Profiles Freed
Nov 10 12:34:59.221: //56/000000000000/SIP/Info/info/8192/sipSPIStopOverlapInfoTimer: Stopping Overlap Info Timer
Nov 10 12:34:59.221: //56/000000000000/SIP/Info/verbose/4096/sipSPIUfreeOneCCB: Freeing ccb 0x7F35BDBB9F50
Nov 10 12:34:59.221: //-1/xxxxxxxxxxxx/SIP/Info/verbose/4096/sipSPIGetContextFromTable: NO context for key[61]
Nov 10 12:34:59.221: //-1/xxxxxxxxxxxx/SIP/Error/httpish_msg_free:
Freeing NULL pointer!
please help me
11-10-2018 04:53 AM
can you post a debug ccsip message so we can see if you are getting authorized by your provider at all?
cheers
11-10-2018 05:12 AM
The debug message above is a debug ccsip all message.
but show sip-ua register status
The state of regi is no.
please help
11-10-2018 02:08 PM
reason is in the debug: "DNS Query for reg.sip-trunk.telekom.de failed".
CUBE has no working DNS hence it can't identify where (which IP) to connect to.
Check DNS on CUBE, once that is working it will get you a step further.
Cheers,
Gunnar
08-01-2019 01:24 AM
01-14-2020 05:58 AM
02-18-2020 04:55 AM
I am having the same issue registering the SIP from DTAG with CUBE. Did you manage to fix it?
