CUC 7.1.5 Compatibility with CUCM 8.6.X
Leonardo Santana
CUC version 7.1.5.30000-117 is compatible with CUCM 8.6.X?
I see this doc but i have this doubt
Note Any version of Cisco Unity Connection 2.x or later is supported for use  with any version of Cisco Unified CM 4.1(3) or later.
http://www.cisco.com/en/US/docs/voice_ip_comm/connection/compatibility/matrix/cucsccpmtx.html#wp38791
Leonardo Santana
Leonardo Santana
*** Rate All Helpful Responses***
Rob Huffman
Hi Leonardo,
That info is most correct and was updated as recently as July of
this year That's why you don't see too may matrix tables
in that "Compatibility" doc.
Cheers!
Rob
"Why not help one another on the way" - Bob Marley
Rob Huffman
Hi Leonardo,
Cheers!
Rob
Once again thanks Rob!
I ask this because we will upgrade the CUCM from version 7.1.5 to 8.6, and CUC will stay at version 7.1.5
Leonardo Santana
Leonardo Santana
Rob Huffman
Hey Leonardo,
You are always welcome my friend
As my Dad used to say;
"better safe than sorry"
Cheers!
Rob
