ā06-29-2015 01:47 AM - edited ā03-17-2019 03:29 AM
My Customer is running on CUC 8.6.2.24089-2. As a part of a bug fix I have suggested them for an upgrade to an ES.
I want to understand the risks of upgrading to an ES and why is an ES release always avoided for upgrade recommendation?.
there seems to be no workaround for the bug, so what all heads up I should give my customer before upgrade?
Solved! Go to Solution.
ā06-29-2015 03:18 AM
There are no specific risks in upgrading to an ES. Yes, the ES is not so rigorously tested as compared to a SU but it does not affect your upgrade process. If there is a SU available for the bug fix then you can apply the same, else you can go for ES. You can check the following discussion on similar question here
https://supportforums.cisco.com/discussion/11550876/cucm-engineering-specials
Manish
Manish
ā07-01-2015 01:28 AM
Thank you for the help!!
ā06-29-2015 06:55 AM
Manish is spot on (+5), the ESes are built to address specific important bug(s) and made available by TAC only. It's also true they do not go through extensive system testing, so there is a slight risk that another new bug can be introduced. You need to wight out your options, is the issues you are addressing big enough to warrant installation of an ES.
P.S. I've installed many ES versions over the years without ever recalling an issue.
Chris
ā06-29-2015 08:31 AM
Hi there,
I'll just add a note to the good tips from my friends Manish & Chris (+5 each!)
It looks like the CUC version the customer is running is already an ES or at least not a version that was released on CCO. I would think if you are concerned about having them install an ES that the latest SU (8.6(2a)su5) would likely incorporate the bug fix you are looking for.
Like the others noted, we've run many ES's over the years without issue.
Cheers!
Rob
ā06-29-2015 09:13 AM
Rob and Chris, thanks for the additional and useful inputs as usual.
Manish
