04-14-2015 05:48 AM - edited 03-17-2019 02:38 AM
We just upgraded from 8.5 to 10.5.1 last weekend. Have an issue when trying to add or make changes to a phone that the following error occurs:
"Add failed. The Insert privilege is required for this operation" I do not get this error but the client service desk does. I mimic my permissions with one of the client services desk and had them try again and still no change. When they make a change, the change does save. However adding phones is not allowed resulted in the same error.
Anyone else run into this?
04-14-2015 07:37 AM
Either Publisher is down or DB replication is broken with it. When we change any configuration, the changes will be written on the publisher and it replicates it to the subscriber even if the changes were done on a subscriber webpage.
Thank you,
Shadi
04-15-2015 08:30 AM
Please mark the question answered if your inquiry is answered.
04-17-2015 05:14 AM
Publisher is not down and DB Replication is not broken. Also ran the DBreplication repair and no change.
04-17-2015 05:40 AM
Is the user able to delete phone or do u get similar error message?
regds,
aman
04-17-2015 07:26 AM
Unable to delete a phone too. Receive this error: Delete failed. No DELETE permission for registrationdynamic.
10-20-2015 07:05 AM
Hi, did you maybe manage to solve this issue? I also have the same problem, publisher is up, DB is OK, but I can't change almost anything in configuration.
Thanks, Dragan
10-20-2015 07:46 AM
This issue has to do with the version I was on - 10.5.1 if I remember correctly. I had to upgrade to 10.5.1 SU1. I was checking my email string with TAC. A work around was also an option w/o having to go to SU1 which I think we tried but still did not resolve. Ultimately it was upgrading that fixed it. The email string did not provide any specific bug information however. I am running 10.5.1.11900-13 now. Hope this helps.
10-21-2015 01:12 AM
I was just going through the bug and found if u are trying to do some changes from SUB and CUCM version is 10.5.0 .
regds,
aman
11-20-2015 12:37 AM
Hi Aman,
Thanks for the answer. I was trying to make changes on PUB directly however. I am about to try an upgrade, as Troy suggested to see if it helps.
Regards, Dragan
11-20-2015 01:26 AM
You can also open the TAC case before doing the upgrade.
regds,
aman
11-23-2015 12:08 AM
Hi Troy,
I've solved the issue by upgrading to 10.5.1SU1, as you suggested.
Thanks a lot!
Regards, Dragan
10-21-2015 12:46 AM
Hi Dragan
Have you try deleting other object like dn/ route pattern etc and see if that works.. Add new dummy device and then try deleting.
Lavanya
11-20-2015 12:29 AM
Hi Lavanya,
Sorry for the late reply...I've tried with adding new device and I got the message "Add failed. The Insert privilege is required for this operation." Thanks anyway!
Regards, Dragan
12-22-2018 06:00 PM
We upgrade from 9.1 to 12. and have the same issue
the upgrade was finished a couple of hours ago
dbreplication looks good, however, we get the message "Add/Update/Delete not allowed due to system upgrade." every time we want to save a change
