05-14-2019 12:41 AM - edited 06-23-2020 12:08 AM
I need to blocked 3 number suspecting from scam.
i have CUCM 11.5
can i know step to perform ?
can it done from router gateway ? we have 3 router
05-14-2019 02:26 AM
05-15-2019 12:28 AM
Hi haris
below procedure will not affect my current setup config
but it really high level also
05-15-2019 01:20 AM
I would suggest using the Voice translation rule for minimum impact
06-23-2020 12:37 AM - edited 06-23-2020 12:43 AM
Yes, you can block it on Cisco Voice Gateway. In all the Cisco routers you need to apply the translation rule, profile and apply to incoming dial-peer pots / voip. Pots in case of PRI and VOIP in case you have SIP trunk.
STEP-1
voice translation-rule 1234
rule 1 reject /^1234567888/
rule 2 reject /^1234567999/
rule 3 reject /^1234567000/
STEP-2
voice translation-profile blockincalls
translate calling 1234
STEP-3.
dial-peer voice 444 pots
description Incoming call from PSTN
call-block translation-profile incoming blockincalls
If in case of SIP TRUNK,
dial-peer voice 4444 voip
Wish I answered your query.
