CUCM 12.5 Decrypt Security Password
Juraj Papic
Level 3
Level 3
Im working with the cucm 12.5 and need to decrypt security password,  I worked with this link for version 11.x and It works with no issue, but in the 12.5 we are not getting the file platformConfig we are only getting the file processnode.
https://community.cisco.com/t5/collaboration-voice-and-video/decrypt-security-password-voice-applications-namely-cucm-uccx/ta-p/3337594
Thanks.
Tested UCOS Versions: 6.1, 9.1, 10.0, 10.5, 11.0, 11.5, 12.0.
Response Signature
6 Replies 6
Response Signature
Juraj Papic
Level 3
Level 3
Any other option?
MICHAEL CICCONE
Just thought I asked the question again.  What about version 12.5?
For UCOS Password Decryptor to display the security password, it requires the platformconfig file, which is not generated on 12.5 by the command “utils create report platform.” This functionality works effectively only up to version 12.0.
If you forget the password, you can reset the security password, as mentioned by @Maren Mahoney . Here is the link on How to reset the security password
https://www.cisco.com/c/en/us/support/docs/unified-communications/unified-communications-manager-callmanager/213527-changing-cucm-os-admin-and-security-pass.pdf
Response Signature
Thanks For the info!
You cannot decrypt it. Period. But you can reset it (and/or the OS password) using the Password Recovery Procedure:
Reset or Change CUCM OS Admin and Security Password
Maren
