02-14-2018 06:32 AM - edited 03-17-2019 12:12 PM
I faced one issue with CUCM 6.1.2 publisher server was having "UNEXPECTED INCONSISTENCY" error while booting and it asked me to insert a recovery disk. I had applied the recovery image and it fixed the corrupted files. However after booting the server, CUCM was pingable and reachable via SSH only but not WEB.
After checking command "utils service list" it shows be the below services only:
System SSH
Cluster Manager
and database was down. I have attached a snapshot of the command results. Could you please check it and inform me if there is any resolution for that issue?
Solved! Go to Solution.
02-14-2018 06:58 AM
License is tied to the MAC address, if you use the same server, same license will work.
02-14-2018 06:47 AM
If the recovery disk didn't work, your best option is to restore from a backup and make sure that the server's HDDs are still in good state.
02-14-2018 06:57 AM
Thanks Jaime for your update.
Do I need to rehost the licenses? Or it should work on the same MCS server and its same MAC address?
Thanks.
02-14-2018 06:58 AM
02-14-2018 07:04 AM
Thanks Jaime. I will try it out.
