취소
다음에 대한 결과 표시
다음에 대한 검색
다음을 의미합니까?
VIEWS
답글
CUCM 7.1.3 - Register rejected to lifesize room 200
wilsonsant
Level 6
Level 6
Hi Guys,
My Customer have the CUCM 7.1.5.31900-3,  it configured the lifesize room 200 as thir party and is presenting error register rejected. This is the correct way to configured this device?
Wilson
9 응답 9
Chris Deren
Yes, 3rd party SIP is the correct way.  Is lifesize using digest user authentication? If so you may need to create the user and assign to the device and then configure on lifesize's side.
Hi Chris,
Thanks a lot for your contact. The Customer create the user and assign to device, but, register rejected continues.
Another idea about this?
Wilson
Hi Wilson.
Just to be sure..
on sip settings username is the extension assigned to sip device on CUCM.
The password is the end user password assigned to device.
Authorization username is the end user username.
Can you please confirm these settings?
Let us know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Hi Carlo,
Thanks a lot for Your contact. The Customer informed to me that configured the samwe username and password, and didn´t worked.
Wilson
On Device page, you also need to configure 'digest user id'. You did?
- Vivek
Hi Vivek,
I will verify with my Customer.
Wilson
Ok and verify one more point at that time, digest password is different from end user password. These are two separate fields on end user page. For SIP registration, you need to use digest password instead of end user password.
- Vivek
Hi Wilson,
do you mean that your customer has configured an end user with the extension as username?
Let me know
Carlo
Hi Carlo,
This information I dont´have. I will verify with my Customer and answer for You,
Wilson
