ā11-16-2015 09:48 AM - edited ā03-17-2019 04:55 AM
Hi Guys,
My Customer have the CUCM 7.1.5.31900-3, it configured the lifesize room 200 as thir party and is presenting error register rejected. This is the correct way to configured this device?
Wilson
ā11-16-2015 10:05 AM
Yes, 3rd party SIP is the correct way. Is lifesize using digest user authentication? If so you may need to create the user and assign to the device and then configure on lifesize's side.
ā11-16-2015 11:57 AM
Hi Chris,
Thanks a lot for your contact. The Customer create the user and assign to device, but, register rejected continues.
Another idea about this?
Wilson
ā11-16-2015 12:57 PM
Hi Wilson.
Just to be sure..
on sip settings username is the extension assigned to sip device on CUCM.
The password is the end user password assigned to device.
Authorization username is the end user username.
Can you please confirm these settings?
Let us know
Carlo
ā11-17-2015 08:55 AM
Hi Carlo,
Thanks a lot for Your contact. The Customer informed to me that configured the samwe username and password, and didnĀ“t worked.
Wilson
ā11-17-2015 08:58 AM
On Device page, you also need to configure 'digest user id'. You did?
- Vivek
ā11-17-2015 09:40 AM
Hi Vivek,
I will verify with my Customer.
Wilson
ā11-17-2015 09:51 AM
Ok and verify one more point at that time, digest password is different from end user password. These are two separate fields on end user page. For SIP registration, you need to use digest password instead of end user password.
- Vivek
ā11-17-2015 09:32 AM
Hi Wilson,
do you mean that your customer has configured an end user with the extension as username?
Let me know
Carlo
ā11-17-2015 09:39 AM
Hi Carlo,
This information I dontĀ“have. I will verify with my Customer and answer for You,
Wilson
