06-05-2013 11:32 PM - edited 03-16-2019 05:43 PM
Do we have a procedure document for replacing MCS7945 I3 server from the existinf CUCM cluster with a new server and adding it back to the cluster.
Please share any doc if you have one.
Thanks in advance..
Sargam Patne
06-05-2013 11:49 PM
Hi Sargam,
It is just like building a new server in the cluster.you need to follow below instructions:
a. Is First Node in cluster ? Select "NO".
b.You need to enter same credentials like Security password, application username/password and Platform username/password?
c. Enter the same Hostname ,IP address, Mask, Gateway and DNS/NTP(if configured) as configured in faulty subscriber.
d. No need to add any licenses in this server.
regds,
aman
06-05-2013 11:53 PM
Hello Aman,
Thanks for the answer.
Do we also need to do a backup of the old server and restore it back on the new one or would the new one take the configuration from the remaining servers upon the completion of the database replication?
Sargam Patne
06-06-2013 12:00 AM
Hi Sargam,
You can take the backup only from Publisher. Also,restore to Publisher.
To be on safe side, just take the backup from DRS from Pub.
After u configure and add the Subscriber in cluster, automatically it would replicate.Make sure u do not select FIRST Node.
Which CUCM version u are using?
regds,
aman
06-06-2013 12:06 AM
Hello Aman,
We are currently using CUCM version 7.1.5
Sargam Patne
06-06-2013 12:08 AM
Hi Sargam,
U can use command utils dbreplication runtimestate to check dbreplication after server is added. Wait for an hour to check DBReplication status.
regds,
aman
