CUCM 8.5 Call Pickup Group Visual Alert
fuhrersk8
Level 3
Level 3
Hello guys!
           I've configured a basic Call Pickup Group and applied it to two 7942G IP phones. On the phones I configured the Pickup button on Line 2. Its working perfect, Im getting the visual alert stating the caller and the called party and the call get picked up if you pressed the Pickup button on line 2. But...the LED on the Pickup button its not flashing when there is an incoming call to the Pickup group! i thpought that the visual alert included the flashinmg of the LED.
Is this possible? Thanks in advanced to all of you guys!
2 Accepted Solutions
Rob Huffman
Hi Nephtali,
This is working as designed There is no Flashing LED with the
Pickup Visual notification;
Call Pickup Notification
The Call Pickup Notification feature provides an audio or visual, or both, notification on Cisco Unified IP Phones when other members of a pickup group receive a call. Call Pickup Notification gets configured in three configuration windows for three types of settings: system, call pickup group, DN/phone.
Service Parameters Configuration—The type of audio notification (beep or ring) to be heard when a phone is idle or busy gets set from the Service Parameters Configuration window. This setting becomes the system default.
Call Pickup Group Configuration—The type of notification for each call pickup group gets configured from the Call Pickup Group Configuration window in Cisco Unified Communications Manager Administration. In addition to configuring the type of notification, you can configure the time, in seconds, to delay the audio and visual alerts after the call comes into that group. This allows the original called party a chance to pick up the call prior to the audio and/or visual alert being sent to the pickup group. See the "Call Pickup Group Configuration Settings" section.
To configure whether the notification will be audio or visual, or both, use the configuration settings in the Call Pickup Group Notification Settings section of the Call Pickup Group Configuration window. The notification gets sent only to the primary line of a device.
To configure the visual notification on the Call Pickup Group Configuration window, use the configuration settings in the Call Information Display For Call Pickup Group Notification section. This setting allows the administrator to have detailed calling party and/or called party information in the notification message. The display will contain the name of calling/called party if available. If not, the number will display. The visual notification comprises a message on the phone status line.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_0_1/ccmfeat/fscpickg.html#wp1072259
Cheers!
Rob
Rob Huffman
Hi Nephtali,
You are most welcome
You can use the "Shared Line" approach where DN xxxx is added to multiple
phones as shown here;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/7_1_2/ccmsys/a03dn.html#wp1100362
Or you could set up the desired "Main DN" as a Hunt Pilot that distributes the calls to
multiple Line group members as detailed here;
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/admin/8_5_1/ccmcfg/b03htpil.html#wpxref28844
Cheers!
Rob
Rob Huffman
Hi Nephtali,
Cheers!
Rob
Thanks Rob! Understood. How can I configured that an incoming call ring out on multiple ip phones at the same time?
Rob Huffman
Hi Nephtali,
Cheers!
Rob
Excellent. Thanks Rob!
