09-11-2013 07:04 AM - edited 03-16-2019 07:18 PM
Hi Guys,
I have the following doubt: I enabled audit log in serviceability and did changes about IP Phone parameters. I collected the logs about RTMT, and I would like know if the logs about RTMT is able to show, for example, change in the display about IP Telephone. I did the test, but, didn´t appear.
10:45:58.014 |LogMessage UserID : administrator ClientAddress : 172.16.64.23 Severity : 5 EventType : GeneralConfigurationUpdate ResourceAccessed: CUCMAdmin EventStatus : Success CompulsoryEvent : No AuditCategory : AdministrativeEvent ComponentID : Cisco CUCM Administration AuditDetails : record in table device with key field name = ABCDEF222222 added App ID: Cisco Tomcat Cluster ID: Node ID: SPOCCMHOMOLOGA
10:46:38.731 |LogMessage UserID : administrator ClientAddress : 172.16.64.23 Severity : 5 EventType : GeneralConfigurationUpdate ResourceAccessed: CUCMAdmin EventStatus : Success CompulsoryEvent : No AuditCategory : AdministrativeEvent ComponentID : Cisco CUCM Administration AuditDetails : record in table numplan with key field dnorpattern = 4002 updated App ID: Cisco Tomcat Cluster ID: Node ID: SPOCCMHOMOLOGA
Wilson
Solved! Go to Solution.
09-11-2013 07:39 AM
Hi Wilson,
In addition to the great info from Aman (+5 Aman!)
The Audit logs available with CUCM via RTMT will not show info down to that
level of changes.
Have a look at Variphy, it does offer a very granular level
of CUCM change audit tracking, plus an excellent
"snapshot" feature.
http://variphy.com/products/enterprises/cisco-audit-log
Cheers!
Rob
"Your life is worth much more than gold."
- Bob Marley
09-11-2013 08:40 AM
09-11-2013 07:14 AM
Hi Wilson,
After u made the change , did u save the config.
regds,
aman
09-11-2013 07:26 AM
Hi Amanso,
I take the 01 DN and changed the display and label text. The logs informed to me that was did change in the specific DN, but, what was changed? Is this information that I need.
11:36:49.535 |LogMessage UserID : administrator ClientAddress : 172.16.64.23 Severity : 5 EventType : GeneralConfigurationUpdate ResourceAccessed: CUCMAdmin EventStatus : Success CompulsoryEvent : No AuditCategory : AdministrativeEvent ComponentID : Cisco CUCM Administration AuditDetails : record in table numplan with key field dnorpattern = 4003 updated App ID: Cisco Tomcat Cluster ID: Node ID: SPOCCMHOMOLOGA
updated, but, what?
Is possible show the specific parameter that was changed?
Wilson
09-11-2013 07:39 AM
Hi Wilson,
This is quite possible, u just get change has been made but what specific change cannot be tracked.You can trach who did it and from which IP address.
Same is true for CSS and Partition as well.
Can u try making change in partition and CSS, see what is appearing?
regds,
aman
09-11-2013 07:50 AM
Hi Aman,
I changed the CSS and Partition and received the same information : updated. Not showed that I changed the CSS and Partition
12:01:19.720 |LogMessage UserID : administrator ClientAddress : 172.16.64.23 Severity : 5 EventType : GeneralConfigurationUpdate ResourceAccessed: CUCMAdmin EventStatus : Success CompulsoryEvent : No AuditCategory : AdministrativeEvent ComponentID : Cisco CUCM Administration AuditDetails : record in table numplan with key field dnorpattern = 4003 updated App ID: Cisco Tomcat Cluster ID: Node ID: SPOCCMHOMOLOGA
09-11-2013 07:39 AM
Hi Wilson,
level of changes.
"snapshot" feature.
Cheers!
Rob
- Bob Marley
09-11-2013 08:00 AM
Hi Rob,
In the version more recently (CUCM 9.x, for example) are there this service integrated? Or is independent? This product offer by variphony is homologate by Cisco?
Wilson
09-11-2013 08:02 AM
Hi Wilson,
One way as suggested by Mr. Rob[+5] , would be third party tool .
the other way round way to enable debug level to Debug which is bit difficult and crude way of finding changes.
Go to Cisco Unified Serviceability -> Trace -> Configuration -> Select Server -> Service Group as Database and Admin Services -> Service as Cisco CCMAdmin Web Service.
Set the Debug Trace Level TO DEBUG and Apply on all nodes.
Go to Cisco Unified Serviceability -> Trace -> Configuration -> Select Server -> Service Group as Performance and Monitoring Services -> Service as Cisco Audit Event Service.
Set the Debug Trace Level to Detailed and Apply on all nodes.
Make the CSS/partition/Name change as u are doing and pull the following traces from RTMT :
RTMT -> System -> Tools -> Trace & Log Central -> Collect Files and check :
Cisco Audit Logs
Now,Download the logs and audit logs will provide IP address information and for the same time CCMAdmin logs will provide changed information
Give a try and check.
regds,
aman
09-11-2013 08:24 AM
Hi Aman,
I did the procedure and not changed the scenario (not appear the field changed). In my test I changed the Partition and include de CSS, because, the DN was configured without DN.
12:23:53.199 |LogMessage UserID : administrator ClientAddress : 172.16.64.23 Severity : 5 EventType : GeneralConfigurationUpdate ResourceAccessed: CUCMAdmin EventStatus : Success CompulsoryEvent : No AuditCategory : AdministrativeEvent ComponentID : Cisco CUCM Administration AuditDetails : record in table numplan with key field dnorpattern = 4004 added App ID: Cisco Tomcat Cluster ID: Node ID: SPOCCMHOMOLOGA
Wilson
09-11-2013 08:40 AM
Hi Wilson,
No idea beyond this.
regds,
aman
