CUCM 8.6 Print phones list with status and ip address
KNYC
Hi All,
I need to print phones list in CUCM 8.6, but under Bulk Admin when trying to print the list there's no option to select status and ip address. We need to print Name, Description, DN, Status and IP address of every phone. Is there a way to do it? Thanks in advance for any kind of help.
Kamran
Aaron Harrison
You can use my free inventory jobbie : www.ipcommute.co.uk
Aaron
Aaron Please remember to rate helpful posts to identify useful responses, and mark 'Answered' if appropriate!
If the number of phones is not huge you can also just search under devices for the phones you want by including queries you are looking for and expending the results to 250 records, then simply highlight all of them and past into notepad/notepad++/etc and you will get nice printout of what you are looking for which will include registration status and IP address.
HTH,
Chris
Claris Systems makes a reporting package that lists everything imaginable, but it's rather pricey. Works well, though.
