CUCM 8.6 Replication cluster status 3
cristian.munoz
Level 4
Level 4
Hi Guys
I have the replication cluster status 3. All nodes are in status 3.
Someone have the procedure to get replication cluster status 2?
TIA
Cristian
23 Replies 23
Hi Cristian,
All nodes in sttaus 3 mean Table are suspect. Server could show Status 3 if a server is down. Have you check if a Subscriber is down?
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
__________________________________________________
Hi Leo
The servers are up.
TIA
Cristian
Hi Aman
I performed the procedure for Fix Dbreplication on CUCM gone Bad, but the RTMT show the replication in state 3 and in the publisher using the command utils dbreplication runtimestate, show the replication in state 0 and one in n/a
admin:utils dbreplication runtimestate
DB and Replication Services: ALL RUNNING
Cluster Replication State: BROADCAST SYNC Completed on 1 servers at: 2013-05-27-12-39
     Last Sync Result: SYNC COMPLETED  541 tables sync'ed out of 541
     Sync Errors: NO ERRORS
DB Version: ccm8_6_2_22900_9
Number of replicated tables: 541
Cluster Detailed View from PUB (3 Servers):
                                PING            REPLICATION     REPL.   DBver&  REPL.   REPLICATION SETUP
SERVER-NAME     IP ADDRESS      (msec)  RPC?    STATUS          QUEUE   TABLES  LOOP?   (RTMT) & details
cucm01  10.240.0.10     0.040   Yes     Connected       0       match   Yes     (3) PUB Setup Completed
cucm02  10.240.0.11     0.109   Yes     Connected       0       match   Yes     (3) Setup Completed
cucm03  10.240.0.12     0.170   No      Off-Line        N/A     ?       No      (?) Not Setup
TIA
Cristian
Crisitan, For what I can see, look like Subscriber cucm03 is down, I told you to check this. Try restarting cucm03 to restart all service.
Hi Cristian,
In addition to what Mr. Leosalcie has said, did u follow the correct procedure as below.
1. Issue the command "utils dbreplication stop" starting with the SUB's (all Subscribers) and then on the PUB. Wait for it to finish on one node before moving to the next.
2. Issue the command "utils dbreplication dropadmindb" starting with the SUB's (all Subscribers) and then on the PUB. Wait for it to finish on one node before moving to the next.
3. Issue the command "utils dbreplication reset all" on the PUB.
regds,
aman
Dear Aman
I will perform the procedure again
TIA
Cristian
Hi Cristian,
Please do that.If u succeed , it's good else u can open a TAC case or try building the Subscriber [CUCM03] again.
regds,
aman
Dear Aman
If the CUCM03 is bad, why the replication is not occurred in CUCM01 and CUCM02?
TIA
Cristian
Dear Aman
After the procedure, the problem continues..
cucm01  10.240.0.10     0.050   Yes     Connected       0       match   Yes     (3) PUB Setup Completed
cucm02  10.240.0.11     0.105   Yes     Connected       0       match   Yes     (3) Setup Completed
cucm03  10.240.0.12     0.166   No      Off-Line        N/A     ?       No      (?) Not Setup
TIA
Cristian
Christian,
Replication is good on CUCM1 and CUCM2. All servers could show state 3 if one server is down in the cluster.
This can happen because the other servers are unsure if there is an update to a user facing feature that has not been passed from that sub to the other device in the cluster.
From the output of the command, the publisher is reporting that the CUCM3 server is offline..Can you ping this server from the publisher?
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
Hello
thanks for your explanation
Yes I can pinging from CUCM03 to Publisher (CUCM01)
(from CUCM03)
admin:utils network ping 10.240.0.10
PING 10.240.0.10 (10.240.0.10) 56(84) bytes of data.
64 bytes from 10.240.0.10: icmp_seq=1 ttl=64 time=0.191 ms
64 bytes from 10.240.0.10: icmp_seq=2 ttl=64 time=0.169 ms
64 bytes from 10.240.0.10: icmp_seq=3 ttl=64 time=0.173 ms
In the CUCM03 the A Cisco DB Replicator service is stop.
admin:utils service list
Requesting service status, please wait...
System SSH [STARTED]
Cluster Manager [STARTED]
Service Manager is running
Getting list of all services
>> Return code = 0
A Cisco DB[STARTED]
A Cisco DB Replicator[STOPPED]  Component is not running
Cisco AMC Service[STARTED]
Cisco AXL Web Service[STARTED]
Cisco Audit Event Service[STARTED]
admin:utils network connectivity
This command can take up to 3 minutes to complete.
Continue (y/n)?y
Running test, please wait ....
Network connectivity test with cucm01 completed successfully.
admin:
admin:utils network host cucm01
Local Resolution:
cucm01 resolves locally to 10.240.0.10
External Resolution:
No external servers found
admin:
TIA
Cristian
What about from the publisher to cucm03.
From Pub
admin:utils network ping 10.240.0.12
PING 10.240.0.12 (10.240.0.12) 56(84) bytes of data.
64 bytes from 10.240.0.12: icmp_seq=1 ttl=64 time=0.187 ms
64 bytes from 10.240.0.12: icmp_seq=2 ttl=64 time=0.182 ms
64 bytes from 10.240.0.12: icmp_seq=3 ttl=64 time=0.200 ms
64 bytes from 10.240.0.12: icmp_seq=4 ttl=64 time=0.164 ms
>> Return code = 0
A Cisco DB[STARTED]
A Cisco DB Replicator[STARTED]
Cisco Bulk Provisioning Service[STARTED]
Cisco CAR DB[STARTED]
Cisco CAR Scheduler[STARTED]
Cisco CAR Web Service[STARTED]
Continue (y/n)?y
admin:
admin:utils network host cucm03
Local Resolution:
cucm03 resolves locally to 10.240.0.12
admin:
TIA
Cristian
