CUCM 8.6 Replication cluster status 3
cristian.munoz
Level 4
Level 4
Hi Guys
I have the replication cluster status 3. All nodes are in status 3.
Someone have the procedure to get replication cluster status 2?
TIA
Cristian
23 Replies 23
Cristian, as I told you before, reboot cucm03 that will restart all service, it should solve the problem.
Please remember to rate useful posts clicking on the stars below.
Favor calificar todos las respuestas útiles dando click en las estrellas de mas abajo.
___________________________________________
LinkedIn Profile: do.linkedin.com/in/leosalcie
__________________________________________________
Hi Cristin,
Any updates, is your problem resolved ?
regds,
aman
nikshah
Christian,
Try running utile network host , ip add , fqdn...
I am pretty confident that server showing offline means that something is fishy with that box, try power cycling it and see if it helps.....
Hi Cristian,
Try rebooting server as suggested else open a case. I got stuck in a similar kind of issue where even after performing the steps mentioned above, we were not able to bring the replication count as GOOD.
We had to rebuild almost three servers in a cluster of four.
regds,
aman
Dear Aman
The issue was solved, using the follow command:
admin:utils network connectivity  cucm03
This command can take up to 3 minutes to complete.
Continue (y/n)?y
Running test, please wait .........
Network connectivity test with cucm03 completed successfully.
admin:
Then,
admin:utils dbreplication reset cucm03
Repairing of replication is in progress.
Background repair of replication will continue after that for 30 minutes....
OK [10.240.0.12]
admin:
After a few minutes..
admin:utils dbreplication runtimestate
DB and Replication Services: ALL RUNNING
Cluster Replication State: REPLICATION RESET cucm03 Started at 2013-05-27-18-19
DB Version: ccm8_6_2_22900_9
Number of replicated tables: 541
Cluster Detailed View from PUB (3 Servers):
                                           PING                          REPLICATION          REPL.          DBver&           REPL.          REPLICATION SETUP
SERVER-NAME          IP ADDRESS            (msec)          RPC?          STATUS               QUEUE          TABLES           LOOP?          (RTMT) & details
cucm01          10.240.0.10          0.037          Yes          Connected          0            match          Yes            (3) PUB
cucm02          10.240.0.11          0.085          Yes          Connected          0            match          Yes            (3) N/A
cucm03          10.240.0.12          0.197          Yes          Connected          0            match          No             (0) N/A
admin:
Finally after a one hour...the replication passed to state = 3.
Thanks for you help.
Regards.
Cristian
Hi Cristian,
Thanks for update.
Did u run utils network connectivity command on Publisher?
regds,
aman
Dear Aman
Yes, correct. All the commands were run on pub.
Cristian
Good... problem got resolved.
regds,
aman
greg.zboran1
I have some logs from a Cisco Phone that seems to unregister from the CCUM. Below is the trace log. I am trying to understand what Status=2 and status=3 means. Does anyone know what this means as the phones stop receiving messages with these status changes. Thanks.
