03-27-2011 10:35 PM - edited 03-16-2019 04:11 AM
Hi ,
I have just finished building a CUCM 8.0.3(a) Cluster. The database replication is all good. I am left with this particular error.
The onconfig.ccm file on 172.22.4.82 does not match the publisher. |
The onconfig.ccm file on 172.25.4.81 does not match the publisher. |
I have restarted the pub as well both subscribers, but still come up with this error. this is an install on UCS blade.
Any idea of what this error might be?
Solved! Go to Solution.
03-28-2011 01:34 AM
There are a bunch of bugs for reporting issues with the onconfig.ccm file, here's one that's not fixed in your CUCM versions CSCtf50227.
03-28-2011 01:34 AM
03-28-2011 03:21 PM
Thanks, Hope is no performance issue.
03-28-2011 04:48 PM
Nope it's just cosmetic.
11-01-2011 10:11 AM
I actually recently upgraded to get around this, but it introduced another problem...
https://supportforums.cisco.com/thread/2113221?tstart=0
Just something to be aware of if you are going to upgrade.
08-29-2017 05:26 AM
bad link
01-08-2013 11:42 PM
Hi Joe,
I am getting the same error on CUCM - 8.6.2.20000-2. Does that mean that the bug is still not being fixed?
Joseph Chirayath
02-07-2013 10:33 AM
Hi all,
same error on CUCM 9.0.1.10000-37.
Regards.
Danilo Molini
05-15-2013 02:09 AM
Hi all,
same error on CUCM 9.1.1.2000-5.
Regards.
Christian Parvex
