05-21-2012 12:38 PM - edited 03-16-2019 11:16 AM
Hi team,
I have a CUCM 8.5 here.
So, I want to create a route group, but I don´t have available devices in call routing> route/hunt > .route group.
Can you help me please?
the print file was attached.
thanks.
05-21-2012 12:43 PM
Hi Jean,
To add a device to a route group, you need to first of all create the device/gateway/sip trunk
Have you added a gateway/sip trunk in cucm? using device>gateway> add new
05-21-2012 12:45 PM
Yes I have!
I Have a environment with 3 sites (1 CUCM and 2 CME-SRST) working properly.
thanks
05-21-2012 12:59 PM
I´m using remote sites configured in gateway.
05-21-2012 01:08 PM
Are you saying you have configured gateways? What type of gateways did you configure? MGCP or H323
05-21-2012 01:08 PM
What that does mean?
Do you have GWs or Trunks defined in CUCM?
If so if they are referened directly by Route Patterns you will not be able to add them to Route Groups, you first need to remove them from route Patterns.
HTH,
Chris
05-21-2012 01:19 PM
I have Gws defined in CUCM.
Ok, I will need a window for this.
thanks.
