05-07-2018 04:46 AM - edited 03-17-2019 12:45 PM
Hi.. I am facing challenge with CUCM 11 pub and Sub as Subscriber is not showing registered under media resource >>conference bridge, although DB replica seems working as any change on Pub is reflecting on Sub also. I tried to reboot Sub as well but still same issue.
Find and List Conference Bridges
05-07-2018 07:26 PM
Hi.. I am able to access Pub network services from Sub, also I have restarted RIS services, even restarted both nodes bit no luck.
05-07-2018 07:49 PM
Hithere
Could you check the status of MTP & CFB under Cisco IP Voice Media Streaming >> Service Parameter. Is that set to True?
then try restarting the IPVMS service again on all nodes.
Cheers
Rath!
***Please rate helpful posts***
05-07-2018 08:52 PM
Hi.. i did same but no luck.
05-07-2018 09:15 PM
Hi.. can it be because of DB replication issue b/w cluster, i could see below error on Pub and Sub..
PUB-
admin:utils dbreplication runtimestate
Server Time: Tue May 8 09:35:56 IST 2018
Cluster Replication State: BROADCAST SYNC ended at: 2017-07-07-19-28
Sync Result: SYNC COMPLETED on 704 tables out of 704
Sync Status: All Tables are in sync
Use CLI to see detail: 'file view activelog cm/trace/dbl/20170707_192547_db l_repl_output_Broadcast.log'
DB Version: ccm11_5_1_12900_21
Repltimeout set to: 300s
PROCESS option set to: 1
Cluster Detailed View from UCM11-01-CONF (2 Servers):
PING DB/RPC/ REPL. Replication REPLICATION SETUP
SERVER-NAME IP ADDRESS (msec) DbMon? QUEUE Group ID (RTMT) & Details
UCM11-01-CONF 192.168.211.143 0.015 Y/Y/Y 0 (g_2) (2) Setup Completed
UCM11-02-CONF 192.168.211.144 0.211 Y/Y/Y -- (-) (-) --
SUB--
admin:utils dbreplication status
command failed -- Enterprise Replication not active (62)
Replication status check is now running in background.
Use command 'utils dbreplication runtimestate' to check its progress
The final output will be in file cm/trace/dbl/sdi/ReplicationStatus.2018_05_08_0 9_34_38.out
Please use "file view activelog cm/trace/dbl/sdi/ReplicationStatus.2018_05_08_09 _34_38.out " command to see the output
Server Time: Tue May 8 09:35:12 IST 2018
Cluster Replication State: dbmonpreflightcheck file is not found.
Repltimeout: Only available on the PUB
PROCESS option: Only available on the PUB
Cluster Detailed View from UCM11-02-CONF (2 Servers):
SERVER-NAME IP ADDRESS (msec) DbMon? QUEUE Group ID (RTMT) & DB Status
UCM11-01-CONF 192.168.211.143 0.222 Y/Y/Y -- (-) (-) Replication Not Setup
UCM11-02-CONF 192.168.211.144 0.017 Y/Y/Y -- (-) (-) Replication Not Setup
05-08-2018 05:38 AM
Absolutely, you need to resolve your database replication issue first. There are many threads and document on how to accomplish that.
05-08-2018 07:30 AM
Oh Yes, thats the key issue here. Pls check out these links.
Hope this helps!
Cheers
Rath!
01-29-2024 12:58 AM
Restarting the RIS data collector service fixed my issue.
