CUCM line report
tato386
Level 6
Level 6
In the CUCM bulk admin menu there are options to update phones and generate reports on phones. There is an option to update lines but no report for lines. I need to scan for lines that do not have auto record enabled. How can I do this?
Diego
Navigate to Bulk Administration > User Device Profiles > Generate UDP Reports. This report allows you to select both device-level and line-level information to generate into a report. At the line-level you can include "Recording Option", "Recording Profile" and "Recording Media Source".
Maren
8 Replies 8
Carlo Poggiarelli
Hi Diego,
Do you need to update lines with recording enabled only?
Please let me know
Carlo
Please rate all helpful posts "The more you help the more you learn"
Yes, I will eventually want to enable recording on almost all the lines and I am pretty sure I know how to do that with BAT. However, before I do that I would like to get a report on current recording status to have as a reference and to make sure lines that we do not want recorded are configured correctly.
Hi Diego,
The easiest way is to export all phones details through BAT , import the resulting CSV on am Excel spreadsheet and make a filter for those phones with recording enabled.
Another option is to make a SQL query through cli to get the same result. If you want I can send you the right command to execute.
Please let me know
Carlo
Hi Carlo,
I guess I should have mentioned this earlier, but the lines are not associated with phones.  They are associated with EM profiles.  Is there a way to export EM profiles like if they were phones?
Rgds,
Diego
You should be able to export the "device profile" from the call manager.
Bulk Administration > Export from call manager administration portal.
Choose Device profile and submit.
Maren
tato386
Level 6
Level 6
I was so focused on "extension mobility" that I didn't see the device profile option in BAT, doh!
Thanks everybody!
Carlo Poggiarelli
Glad to help.
Cheers
Carlo
