CUCM login error
sonisdreams
I am unable to login in my Pub CUCM. and getting error " Database communication error ".
kindly suggest for troubleshoot steps.
Regads,
Deepesh
13 Replies 13
Aman Soi
Hi Deepesh,
What is CUCM version u are using?
How many servers do u have in cluster?
regds,
aman
Hi Aman,
System version: 7.1.5.33900-10
when I logged in with cli, I found A cisco DB service is stopped state in this pub and working in other subs in cluster.
bye
deepesh
Hi Deepesh,
Can u share the output of command from Pub and any SUB in cluster
utils dbreplication runtimestate
Also, in  SUB, from Cisco Unified Reporting Tool ,share snapshot of cdr list serv
regds,
aman
Output from Pub :
admin:utils dbreplication runtimestate
Database is down; please restart the database before reattempting a status check
admin:
Output from Sub :
DB and Replication Services: ALL RUNNING
Cluster Replication State: Only available on the PUB
DB Version: ccm7_1_5_33900_10
Number of replicated tables: 427
Cluster Detailed View from SUB (3 Servers):
                                PING            REPLICATION     REPL.   DBver& R        EPL.    REPLICATION SETUP
SERVER-NAME     IP ADDRESS      (msec)  RPC?    STATUS          QUEUE   TABLES L        OOP?    (RTMT)
MPJBPCCCCUCM1   10.10.18.78     0.145   No      Active-Dropped  351100         ?        N/A     (?)
MPJBPCCCCUCM2   10.10.18.79     0.023   Yes     Connected       0       match  N        /A      (3)
MPJBPCCCCUCM3   10.10.18.80     0.164   Yes     Connected       0       match  N        /A      (3)
admin:
and unable to fatch cdr list serv.
thanks
Hi Deepesh,
Seeing the output, it seems that Publisher logical connection is Dropped.
Can u try command from Subscriber utils dbreplication stop all on both subscribers? Wait for it to finish and then move to next node.
utils replication dropadmindb on all servers. Wait for it to finish and then, move to next node.
after that run the command utils dbreplication reset all  on Pub.
After the same is done , run utilsdbreplication runtimestate to check status which could take time say for an hour.
Any change which u did in Publisher like changing DNS, hostname .
regds,
aman
Note that the OP wrote: "A cisco DB service is stopped state"
*This* is the first problem I'd fix.
GTG
Please rate all helpful posts.
Pls discribe
Your publisher's database isn't running! That's what's causing all the problems.
On the console, try:
utils service start A Cisco DB
GTG
I have already tried it its show :
admin:utils service start A Cisco DB
Service Manager is running
Component is not running
A Cisco DB[NOTRUNNING]
In which case your Publisher's database is failing to start. I suggest a call to TAC.
GTG
Hi Deepesh,
Is your problem resolved?
regds,
aman
Hi Aman,
Yup........ it is resolved by restarting the device.
There was no change in DNS or hostname.
Thanks for quick response.
Hi Deepesh,
Thanks for update.
regds,
aman
