01-14-2021 12:47 PM
I deployed a Call Manager (version 12.5) with Extenion Mobility.
In System>Service Parameters I disable the logout timer in Extension Mobility service:
Enforce Intra-cluster Maximum Login Time => False |
However, I can see on my Phone that there is a Log Out Time:
Log in Time | jeudi 14 janvier 2021 15 h 30 GMT |
Log out Time | jeudi 14 janvier 2021 23 h 30 GMT |
How can I disable the log out time ? I want the phones to stay login until user manually logout.
Thank you !
01-14-2021 01:53 PM
This parameter specifies the maximum time that a user is allowed to be locally logged in to a device, such as 8:00 (8 hours) or :30 (30 minutes). The system ignores this parameter if the Enforce Maximum Login Time parameter is set to False. |
This is a required field. | |
Default: 8:00 | |
Maximum length: 7 | |
Allowed values: Valid Input should lie between 0:00 and 168:00 in the format HHH:MM where HHH represents the number of hours and MM represents the number of minutes. For example, for 168 hours, enter 168:00; for 25 hours and 15 minutes, enter 25:15; for 30 minutes, enter :30; for indefinite login, enter 0 or 0:00 or :00. | |
Unit: Hours:Minutes |
01-15-2021 12:44 AM
Hello Jaime,
THank you for your answer.
In fact the Enforce Maximum Login Time parameter is already set to False.... And I still have a logout timer.
I tried to restart the EM service, no difference.
Thank you
Best regards
01-15-2021 04:49 AM
Do you have it set like this?
