Beginner
CUCM Mixed Mode
Hi experts, would like to check if there is any license requirement for moving CUCM 12.x cluster to mixed mode ? (enable encryption). Thanks
1 ACCEPTED SOLUTION
Hall of Fame Cisco Employee
Re: CUCM Mixed Mode
Your smart account needs to be able to generate a token with "Allow export-controlled functionality" in order to enable mixed mode.
java
if this helps, please rate
9 REPLIES 9
VIP Advisor
Re: CUCM Mixed Mode
as far as I know you dont need additional lics for that.
make sure you have restricted software installed, otherwise you will be flogging a dead horse.
Please remember to rate useful posts, by clicking on the stars below.
Re: CUCM Mixed Mode
java
Re: CUCM Mixed Mode
Hi Shankar,
This requires export controlled functionality in smart licensing.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/srnd/collab12/collab12/security.html#pgfId-1322088
To run CUCM 12.0 in Mixed Mode, it is necessary to successfully register the CUCM 12.0 with the "restricted" Registration Token from Smart Account. If you already have a Smart Account with Export functionality allowed, and you are running CUCM 12.0 in Mixed mode, make sure the token option checkbox for "Allow export-controlled functionality" is checked (which will generate a restricted Registration Token).
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/admin/12_0_1/systemConfig/cucm_b_system-configuration-guide-1201/cucm_b_system-configuration-guide-1201_chapter_011.pdf#page=4
Hope this helps.
Shashank
Re: CUCM Mixed Mode
Hello Cisco Community,
Same Question but the version of CUCM is 10.5? do i need encryption license in running Mixed Mode?
Highlighted
Rising star
Re: CUCM Mixed Mode
Cisco Unified Communications Manager, Release 10.5(2)SU6 requires an encryption license to run the product in mixed mode.Check Release Notes for Cisco Prime License Manager, Release 10.5(2)SU1a .
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
Rising star
Re: CUCM Mixed Mode
Thanks for the update. The release notes for PLM mentions that Cisco Unified Communications Manager, Release 10.5(2)SU6 requires an encryption license to run the product in mixed mode.
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/plm/10_5_2_SU1/releasenotes/cplm_b_release-notes-1052su1/cplm_b_release-notes-cplm-1052su1_chapter_010.html
Re: CUCM Mixed Mode
Your TAC engineer is wrong, you DO need an encryption license on 10.5(2)SU6, see slide 114
https://www.ciscolive.com/c/dam/r/ciscolive/emea/docs/2018/pdf/BRKUCC-2501.pdf
java
Re: CUCM Mixed Mode
Hi Jaime Valencia,
Thank you for confirming, yes your correct,  my TAC Engineer told that he overlooked it and saying sorry about what he said.
Is the Encryption License free?
Everyone's tags (1)
Content for Community-Ad
August's Community Spotlight Awards
