IP Telephony and Phones
Personalize banner_3
Labels
We have a newly activated E1 port which flaps frequently in 3-4 days where layer 1 goes down and up. Its a 4351 cisco router. What type of cable you need to connected to E1 port ? RJ45 or RJ 48 ? CAT6 or CAT7 ? Crossover or Straight or its specific f...
Hi all, Minor issue with our VTC caller ID. Check this out: When any Video conferencing unit dials a VoIP as an audio participant in a conference, the VTC phone number shows as the called VoIP phone's own number.  The text Caller ID description does ...
R_Acuti by Level 2
  • 559 Views
  • 0 replies
Hi, I have the below setup When phone (PH2 10.0.5.10 ) calls  ( which is connected through a tunnel )  PHONE 3 , I am facing audio issues . There is route from 10.0.5.0/24 to 1.1.1.0  and fw policy is there in place . Apart from that what could be is...
Resolved! SIP Trunk Query
Hello Everyone, I have a query regarding SIP trunk configuration on CUCM. Below is the setup: CUCM 1 (SIP Trunk, DP:5060) >>> CUCM 2 (SIP Trunk, DP:5061) If I configure SIP trunk from CUCM1 towards CUCM2 using port 5060, but on CUCM 2 I create a SIP ...
My cisco 7939 phone is not registering on my CUCM6.0.1, I have installed the device update for 6.0 and the lastest device firmware for 7937G yet, i cannot find the new firmware in the firmware load information and the device default/phone button temp...
