CUCM MOH - No messge heard
dtom
We are running CallManger ver 7.0.1 with the default MOH settings using the SampleAudioSource (Cisco default) music.  Now, we want to add a new MOH message - OnHoldMessage.  Here is what we did:
1) From Music on Hold Audio File Management - Upload File (OnHoldMessage.wav)
2) From Music on Hold Audio Source - Add New
      MOH Audio Stream Number - 2
      MOH Audio Source File - OnHoldMessage
      MOH Audio Source Name - OnHoldMessage
      Play continuously (repeat) - checked
3) From a Phone Directory Number Information - change User Hold MOH Audio Source from SampleAudioSource to OnHoldMessage
We test this by calling this phone and putting the call on hold.  No message or sound is heard.  We change it back to SampleAudioSource and then call this phone and put the call on hold.  Now we hear the sample cisco music.
What are we missing here?  Any help would be appreciated.
Chris Deren
Make sure you upload the MOH on all servers.
Chris
Chris Deren
Chris
Ayodeji Okanlawon
How many servers do you have? Have you uploaded the file to all the servers.
Did you record the file int he right format?
Prompt format is CCITT u-Law (64Kbps), 8 kHz, 8 bit mono
Please rate all useful posts
If you're not using G711 for all calls also make sure to enable the necessary codecs from the IPVMS service parameters.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
java
That was it.  I needed to upload to all server.
