CUCM On VMWare DHCP Issue
CUCMCenter26681
I have CUCM 10.5 on vmware workstation
  and My VM bridged to my network Card of My PC
  and I Configured DHCP server and DHCP Subnet
But when I connecting my IP phone to PC and configuring dhcp "YES"
      It should get ip from range of CUCM DHCP Subnet
But It's Not
If anyone Help
     be Grateful
7 Replies 7
CUCMCenter26681
Any Help Please
Chris Deren
So, if DHCP configured on your CUCM server and you want a Cisco phone to obtain an IP address from it?
A device such as a phone will get IP address from any DHCP server defined for that subnet by sending out a broadcast asking for DHCP or if one is not defined within the broadcast domain it will look for ip helper address.  How is the switch that your phone is connected to configured for DHCP?
Hello Chris Deren    &    Thank you
So My Switch is with no any configuration (Dummy)
and I have tried to connect My IP Phone to My PC (VMWare) directly but same Issue
Thank you  So Much
How is your phone connected to the VMware?  What is suppose to provide the DHCP here?
Do yourself a favor and do it correctly.  Configure DHCP scope somewhere, i.e. switch, home router, CUCM, incude option 150 in the scope pointing to the CUCM TFTP server, and connect the phone to a switch directly. Let it pull the IP address from the DHCP scope along with the option 150 so it can talk to CUCM.
I Mentioned Previously That I Configured DHCP Server and DHCP Client on CUCM
It Suppose that's Enough to push dhcp for VoIP that connected Directly
Thank you for your help
Anthony Holloway
You didn't mention if you activated the DHCP service or not, and it's off by default.
Go into CUCM > Serviceability > Tools > Service Activation > DHCP Monitor Service
Hello Anthony
and thank you for your reply
I Already Activated DHCP Monitor Service
