07-04-2014 07:02 AM - edited 03-16-2019 11:18 PM
Hey,
I hope someone can shed some light as I have never seen this issue.
CUCM 9.1
Phones 8945
Problem:
Has anyone seen this issue
Solved! Go to Solution.
07-04-2014 07:50 AM
Hi there,
I'll just add this note to the good tips from Suresh (+5 )
It may be this bug;
Symptom:
8945 when receiving second call, first callers voice goes to speaker but no speaker button lit
Conditions:
When 'Ring setting (phone active)' configuration on the line config is set to 'Use System Default' and Service parameter 'Ring Setting of Busy Station' is configured for "RING"
Phone A (any phone) calls Phone B (8945) Line 1 -> Phone B answers with handset -> Phone C (any phone) calls Phone B Line 1 -> with no user interaction original caller (phone A) heard Phone B speaker. No speaker button lit.
Workaround:
change Service parameter 'Ring Setting of Busy Station' is configured for "Flash" or "Beep"
Or upgrade as Suresh suggested;
Known Affected Releases: | (1) |
Known Fixed Releases: | (1) |
Cheers!
Rob
07-04-2014 07:23 AM
what is firmware of the phone ?
Suresh
07-04-2014 07:26 AM
Thanks Suresh,
SCCP894x.9-2-3-5 |
07-04-2014 07:41 AM
I did search for the bug but didnt find specific to this firmware. Can you are try upgrading phone' firmware on CUCM.
Suresh
07-04-2014 07:50 AM
Hi there,
It may be this bug;
Symptom:
Conditions:
Workaround:
Cheers!
Rob
07-04-2014 08:24 AM
Thanks both of you appreciate it a lot. I am not sure if this issue below could be related to
Scenario 1 ( FAIL) Incoming call:
Scenario 2 ( FAIL) Incoming call:
