09-12-2018 02:06 PM - edited 09-12-2018 02:06 PM
Hello all,
I'm currently working on a project to upgrade CUCM from 9 to 11. It turned in to a migration project instead of an upgrade because we wanted to put CUCM 11 in new address space. I currently have the migration done, so CUCM 9 is still in production, CUCM 11 is off in the new space and is an exact copy of the CUCM 9 environment. The last step in this project is to put CUCM 11 into production and shut down CUCM 9. I have a TAC case open, but I'm looking for input from people who have done this before. What I'm currently dreading is the gateways. I'm going to have to get the gateways registered in the new call CUCM 11 and I'm going to have to get the phones to check in with new CUCM 11.
My PCD migration task is currently paused after the migration, the next tasks are to shut down each node in the cluster, which I haven't continued because the actual switch over to the new CUCM 11 won't be until a week an half from now.
I'm just looking for any advice on the timing of all of this. I believe I will need make changes to the new CUCM11 configs to get the gateways to register in the new call manager, and I also believe I will need to do something with the phones to make them check in and register with the new CUCM 11. And I believe this will need to be done within the window of time I have to make the switchover to CUCM 11. I'm just hoping to find someone who can give me an idea of what to expect and how they timed it out when they were making the cut over.
Thanks in advance
There's a ton of info out there but it's tough to find the right info and I just wanted to see if I could get some advice from someone
09-12-2018 07:55 PM - edited 09-12-2018 07:56 PM
You will have to deal with the ITL files on the phones in relation to the new cluster. You will have to migrate them to the new cluster. Check out these links.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/pcdadmin/11_5_2/cucm_b_pcd-admin-guide-1152/cucm_b_pcd-admin-guide-1152_chapter_0111.html?bookSearch=true
https://supportforums.cisco.com/document/60716/migrating-ip-phones-between-clusters-cucm-8-and-itl-files
http://www.uccollabing.com/2016/08/23/migrating-itl-files-between-cucm-clusters/
As far as the gateways you will have update the CCM-Manager for MGCP to the new addresses.
Also you will have to change the OPT 150 on the DHCP servers.
Hope that helps a bit.
09-12-2018 08:44 PM
Things to prior to the cutover, assuming no IMP in the picture:
During cutover:
