CUCM publisher crash
samhopealpha
Hi Everybody,
I'm now using CUCM 8.6 with a publisher and a subscriber
Now the publisher is crash and need to be installed again.
Is there anything I need to be aware, or just install as normal and restore the CUCM backup?
Thanks in advance
Sam
Chris Deren
Install, restore from backup and ensure db replication is ok. Endure you rebuild the pub with same parameters such as host name, IP address, etc.
Chris
5 Replies 5
Chris Deren
Chris
What if the backup hasn't been done before, can I use the DRS backup from subscriber and restore to publisher ?
Sam
Chris Deren
Unfortunately no, you cannot backup the sub. Backups are only done on pub. If you never got one then you are out of luck and you need to build the system from scratch.
Chris
Thanks for the quick reply, but I still have one more question...
Now I found the backup file, but I only got the CUCM1's backup (publisher), for the CUCM2's backup (subscriber) is lost
Is it possible to restore the CUCM by using the publisher backup file only?
Publisher backup file exists
UCM          CUCM1          REPORTER
UCM          CUCM1          CDPAGT
UCM          CUCM1          SYSLOGAGT
UCM          CUCM1          TCT
UCM          CUCM1          PLATFORM
UCM          CUCM1          CCMPREFS
UCM          CUCM1          CCMDB
UCM          CUCM1          CLM
UCM          CUCM1          TFTP
UCM          CUCM1          ANN
UCM          CUCM1          MOH
Subscriber backup files lost
UCM          CUCM2          SYSLOGAGT
UCM          CUCM2          CDPAGT
UCM          CUCM2          PLATFORM
UCM          CUCM2          CLM
UCM          CUCM2          TCT
UCM          CUCM2          TFTP
UCM          CUCM2          ANN
UCM          CUCM2          MOH
Hi Sam,
The backup for the pub is what is important. The SUB will then replicate the PUB database. The DRF framework backups up the TFTP, MOH and infraestructure component for the SUB, but it's not critical.
We have a new feature on CUCM 8.6 where you can take a backup from a SUB and restore it on the PUB, only catch is the backup device needs to be configured prior to the PUB crashing.
We believe this new feature might alleviate some issues for our customers in the future.
