CUCM -SIP Trunk - MAX forward
iptsupport
Level 4
Level 4
Hello all ,
When we try to call to specific destination , the call disconnect .
The scenario is : CUCM->SIP TRUNK TO Provider->provider
we got error 483 "too many hops"
The provider of calls request to change the amount of MAX-FORWARDS in PBX .
How we can modify the Max-forward value of SIP trunk ?
my CUCM version is 10.5.2
Kalliopi Vazima
i think you should consider sip normalization using lua scripts.
Also check the following older reply in community.
https://community.cisco.com/t5/ip-telephony-and-phones/sip-trunk-between-cucm-and-isp/td-p/3338469
Kalliopi
Please Rate Posts (by clicking on Star) and/or Mark Solutions as Accepted, when applies
GI Alex
In CUCM 12.5 Max-Forwards parameter is available as:
Maximum Redirections parameter in SIP Profile - Allows you to use this configuration variable to determine the maximum number of times that the phone allows a call to be redirected before dropping the call. Default specifies 70 redirections.
Kind regards,
Alex
If you have an SBC between your CM and the service provider you can change this with a SIP profile.
Response Signature
