CUCM Speed Dial configuration from Phone App
ewaizel
Hi Forum
I know it is possible to configure Speed Dials from the CUCM URL. We don't want to give users access to this.
We would really like them to configure their own Speed Dials from their phones.
I can see this is possible in the BE4000 (8800 phone: My Phone Apps > Speed Dial).
My question is about CUCM (ver 12.0). I cannot find something equivalent here.
Did any of you have this requirement?
Thanks.
Jaime Valencia
88xx can use local speed dials if you use FW 12.1, review the info for that firmware version.
Caveat is, they DO NOT sync with CUCM, and they can be overwritten by EM and will be lost.
java
if this helps, please rate
Jaime Valencia
java
Appreciated Jaime!
